Thats the trouble with turbochargers. Whilst simplistic in components they have precise tolerences.
Unless these aftermarket compressor wheels come with precise machining dimensions, looks like a recipe for trouble. If there is contact between the wheel housing whose fault is it going to be? Answer - Yours! Either because the dims were incorrect or the assembly was.
Another issue is that there are more than one K27 compresor housing. The 7200 was I believe a superback design like the RS2 so was a step change in design from the regular stuff. That means the backplate and associated hardware would also be different. So you may not be able to fit a desired wheel within your comp housing anyway.
Yes, that is completely right. Since I do not know the housings and backplates, and I do not build turbos, I do not know, what else is necessarly to fit the compressor wheels.
