Finally: Bluetooth diagnostics/logging for the B4
  • EspenW
    • Apr 2007
    • 1534
    • Country: Norway
    I have used Vagcom since 2001 or so and love it, but I have been spoiled by the Bluetooth based solutions for the OBD2 protocols in the post 1996 cars as it only takes an inexpensive BT dongle in the diagnostics port and a free app for your phone in order to see live values, etc for the OBD2 cars.
    On our B4s, we have to drag out the laptop in order to use Vagcom, and for logging, I would have the cable come out through the bonnet and in through the window.
    In other words, I have been on the lookout for a Bluetooth solution for the B4s.
    Enter obdeleven.
    FINALLY a Bluetooth solution that works with our pre OBD2 cars:
    www.obdeleven.com
    The BT dongle is approx. 30 quid including shipping and the basic version app is free. Pro version (more helpful for the newer cars) is around 50 pounds.
    Note: only Android at the moment.
    We need a 2x2 adapter, but they are only a couple of quid on Ebay.
    http://www.ebay.com/itm/VAG-COM-Audi...oAAOSwHMJYLpW8
    Can be purchased inexpensively from obdeleven as well.
    For those familiar with Vagcom, obdeleven has most of the features that we know from that (fault codes, basic settings, programming, etc), so much more than standard OBD2 stuff.
    The RS2 is in winter hibernation until March or so, but I'm looking forward to seeing live data on my phone for timing, IAT, etc.
    I have tested it (w/o starting the engine, and it works great!)
    See pics below:
    Live data (engine not running):
    Dongle and 2x2 adapter:
    Fault codes:
    Protocol and engine info:
    1994 80E Avant
    1986 2L Golf 2 on Alcohol
  • mouse
    • Apr 2008
    • 374
    • Country: Australia
    Looks great.
    Unfortunately iPhone version looks to be a while away, if at all.. http://obdeleven.proboards.com/thread/430/ios-version
    • EspenW
      • Apr 2007
      • 1534
      • Country: Norway
      Originally posted by mouse
      Looks great.
      Yep, IOS is likely some time away, and might not happen.
      However, Android based devices like basic phones and tablets can be bought dirt cheap.
      My main phone is Windows based (pathetic when it comes to available apps) HTC, so I use an old (but great) Sony Xperia with the OBDeleven.
      1994 80E Avant
      • spink
        • 4382
        Looks good apart from I read on YouTube something about needing credits?is that correct? Ruins the the thing if you have to pay again everytime you use it
        • Michael S2
          • Dec 2011
          • 1378
          This sounds excellent. Thanks for posting
          1995 Audi S2 Avant
          • hunker7
            • Mar 2014
            • 3487
            This is great, thanks for sharing
            '93 Audi UrS4 Avant
            '15 Audi A7 quattro 3.0 TDI
            • EspenW
              • Apr 2007
              • 1534
              • Country: Norway
              The credits are basically for one touch coding features., which really only applies to the newer cars (program taillights, etc). You can still code without using credits, but with the multiple step method (like you have to when using Vagcom).
              Check this video: https://www.youtube.com/watch?v=tesklrp019E
              Note that you can get free credits as well.
              For the B4s, credits only applies if you have the basic version and want to watch live data, as live data is a Pro only feature, but by using credits (in this case 5 credits), you can watch them with the free basic app as well.
              You can get 5 or 6 free credits per day just by clicking on an ad, so it only takes a few seconds. Pretty much the same system as many other free apps with ads and paid apps w/o ads, but here you decide yourself if you want to see the ad (and get free credits). Works well.
              1994 80E Avant
              • RichLV
                • Mar 2015
                • 872
                • Country: Latvia
                Now I need to throw my iPhone into the bin...
                  Looks great!
                  • Filip_FIN
                    • Feb 2016
                    • 332
                    This looks very nice ! Thanks for sharing
                    Project Audi s2 coupé 1996
                    http://http://www.s2forum.com/forum/showthread.php?t=80796]
                    • Bowie69
                      • Nov 2013
                      • 2675
                      I wonder what the abilities of it are for late model 4-connector 7A ECU.... would be wonderful to get inside the running figures of my engine... and well worth it too.
                      • Siim89
                        • May 2016
                        • 14
                        Has anyone tried live data with this for 2+2 connector car? Excellent if the example is of prj mapped me2.3.2.
                        • Bowie69
                          • Nov 2013
                          • 2675
                          It certainly says it can work with 2x2 connector, I mean essentially a 2x2 connector is just a different shape to an OBD port, the wires are the same!
                          • EspenW
                            • Apr 2007
                            • 1534
                            • Country: Norway
                            What kind of diagnostics connector does it have?
                            1994 80E Avant
                            • Bowie69
                              • Nov 2013
                              • 2675
                              2x2, now with and obd adapter in it
                              The ECU itself has 4 separate plugs with lots of wires, as opposed to the early 7a which had 1 or 2 connectors.
