Mark's Catch Tank
  • Mark Halligan
    • 2001
    Blimey!
    Just got back from a couple of days away on a course with work, so much to read!!
    Doug,
    Basically I removed all of the original breather pipes and hoses from the
    engine and I mounted the Mocal unit on the strut brace bar. The Mocal has two
    inlets and I connected one of these to the main breather outlet on the left
    side of the block (looking forwards). The other I connected to the rear of
    the cam cover, the one to connect to here is the smaller one that is lower down on the cam covers rear, as this
    carries the crankcase pressure, the top one is just a transfer pipe to carry the crank fumes to the front of the engine for ingestion by the inlet, in the OEM configuration.
    As I found that there was quite a bit of oil being 'puked' up into the can, I therefore decided to replace the cans drain plug with another line that travels down to a modified sump plug to drain the oil back to the sump. It is important that the oil drains back to the sump below the oil level as if it is not, crankcase pressure will also travel up this hose and the oil will not drain back while the motor is running.
    Additionally the cap that comes fitted the Mocal is breathable to allow the fumes to exit the system, this is obviously absolutely essential.
    I found that these were entering the car from the engine bay via the ventilation system so I replaced the cap with an adapter and connected it to a hose that vents the fumes to atmosphere through the inner wing to the wheel arch through a small K&N type filter, this is hidden by the wheel arch liner. This solution I am told is legal but you may want to divert the fumes after separation to the intake boot as in OEM configuration to be disposed of by ingesting into the inlet. If you decide that this is the way you want to do it, it would be better to use the cyclone type separator as this uses a centrifugal type action to separate the fumes from any oil, but be aware that these fumes will still carry suspended oil droplets in them and the only way to ensure a CLEAN inlet charge is to vent to atmosphere, or to the exhaust downpipe like Bigtoe has posted, that looks interesting but I have'nt had a chance to read it properly yet as I have only just sat down at the PC.
    I used all aeroquip type fittings and stainless braid hoses on the installation, but thats just because I'm a tart for shiny things.
    You could of course use normal type hoses with no loss of performance as the system is basically low pressure and it would also be much cheaper to do that way.
    Cheers Mark.
    Mark - Modded
    • Mark Halligan
      • 2001
      Connection to sump plug:
      Mark - Modded
      • Mark Halligan
        • 2001
        Modified sump plug:
        Mark - Modded
        • audiman
          • 4827
          Paul, N.I. Mots are a totally different set of rules to UK Mots. It may be that you do need a closed breather system over there. :confused:
          Not sure, but over here its OK
          Tom C - www.rcmr.co.uk
          Audi UR Quattro
          Audi 100 C3 2.0 5 cyl 115ps
          Audi B5 RS4 645ps 911nm
          • Doug_RS2
            • 3847
            #35
            So is this right now?
            • Sweeper
              • 1317
              • Country: Latvia
              #36
              Doug: If the picture is correct you should work for Quattro and Audi Gmbh as manufacture costs reduction engineer
              Vadim.
              • Mark Halligan
                • 2001
                Doug,
                Yep, thats right, but I think I would keep all the old bits in a box somewhere .
                Mark.
                Mark - Modded
                • Sweeper
                  • 1317
                  • Country: Latvia
                  #38
                  Mark: Isn't 20V_krummer list has a detailed sheme and pictures of Cyclone in their files section ?
                  You should look more at http://autos.groups.yahoo.com/group/...ruemmer/files/
                  At "Breather Sys" Directory and "Crank_bre_....ppt" and "Crank_breath...ppt" files.
                  Guess this helps.
                  Vadim.
                  • Mark Halligan
                    • 2001
                    Bigtoe,
                    Thats brilliant mate, gonna definately try that, I remember reading a thread on Kruemmer, here:
                    Which mentions the benefits regarding power increases gained by creating a vacuum within the crankcase.
                    Oh well more to do
                    Does anyone have an idea of what type of one way valve could be used?
                    Mark.
                    Mark - Modded
                    • Dr H
                      • 1175
                      ****** 'ell you can get rid of all that plumbing!
                      That might be an idea for any S2 monster power or not.
                      Also less hoses to leak
                      • Doug_RS2
                        • 3847
                        #41
                        Good - getting somewhere now - Next question is the pipe that connects to hose number 23 in the pic - what is that and what have you done with that? (blocked it off?)
                        What is that thing that is connected to the t of the t-piece 21?
                        • Josh-stateside
                          • 741
                          Doug
                          Carbon canister vavle connects to 21
                          The vacumn line on the intake manifold connects to 23
                          Josh
                          • Doug_RS2
                            • 3847
                            #43
                            Cheers Josh - is this the thing that is connected to the fuel tank and vents extra pressure into the intake system? What happens to this then? I wouldn't have thought you would block this or vent it to atmosphere.
                            Just block this pipe then?
                            • Josh-stateside
                              • 741
                              I don't know the technical sides of motronic to comment on this enough yet, but I have been reading:
                              " you may that the evaporative fuel control system stores fuel vapors in a charcoal canister to be drawn into the running engine upstream of the throttle...."
                              I don't think you can "ditch" it, but like I said currently above my knowledge known.
                              • Mark Halligan
                                • 2001
                                Doug,
                                I have left it connected to the inlet manifold and blocked the outlet that would have been connected to the crankcase ventilation pipe (this would have gone to the intake boot). This has caused me no problems, but I will probably connect the blocked off end to the intake again at some point in the future.
                                Link here explaining how it works:
                                With the solenoid outlet blocked, the connection to the inlet manifold fitted with a one way valve (to stop the fuel tank being pressurised during boost conditions in the IM) will still vent the carbon cannister.
                                Mark.
                                Mark - Modded
