Ok - So what cars have a longer throttle cable? Is the AAN the same but longer?
AAN Inlet Manifold on ABY
All I need to do now is fit a bracket to fix the rad in place, fit the front slam panel, fit the exhaust adapter and fill with fluids.Attached FilesS2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8
And anotherAttached FilesS2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8
yet anotherAttached FilesS2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8
And my throttle cable bodge - I cut an end off an old throttle cable and connected the 2 cables together - it will do for now - Tom will be proud of the bodge - I have to maek sure I can get WOT with it though.
My mate, Simon, gave me the idea to bodge it - it will probably stay like thatAttached FilesS2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8
Here is a picture of my exhaust bodge - this is connecting my 3" Marco downpipe - to my current 2.5" exhaust - this it replaces the 2 y sections and the 2 cats/replacement pipes. I am waiting to see Toms side exit before I decide to do that or not.Attached FilesS2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8
WTF is that mostrosity mate?? Looks as bad as my heat shield bodge!! I guess Stevie Wonder is now providing welding and fabrication services in Scotland...album sales must be down. LOL.
Nice hoses BTW ;-)1995 S2 Avant with some upgrades
Designun Limited....
it is a BODGE - lets see your welding Lee If I wire brushed it, it would look a lot better.
Half the hoses I used were scrap or cuts from the set I got to fit the intake. BTW - I could do with some vacuum hose - as the long bit I had is too short to route properly to the diverter.S2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8
Originally posted by LeeWhere is your ISV Doug? Is it far from the butterfly?S2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8
My welding isn't too bad especially with Oxy...then it gets beautiful. Must learn to TIG but can't afford one yet to play with. I made my crank locking tool using an Arc welder..5 minutes practice and the old skills were back. MIG is crap for making nice welds unless you use it a hell of a lot.1995 S2 Avant with some upgrades
I can do some beautiful welds with the MIG - I am just not consistant with it - some time it is real nice - most of the times it is a ****ing mess - I am very proud of my nut I welded on the DP to plug in Mihneas EGT gauge - that is as near perfect as I could ever hope for - pity about the other 3 metres of welds.S2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8
Originally posted by martinjsNot far off now doug
have you cut a hole in the bumper yet?
I need to cut a couple of slots under the bumper - I have 2 struts coming off the bottom of the IC to stop the IC moving - and it is too tight a fit over those bolts/struts.
DOes anyone know where to get RS2 style mesh? A hexagon style mesh?S2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8
