AAN Inlet Manifold on ABY
  • Mark Halligan
    • 2001
    Originally posted by Doug_RS2
    I know - but Mark had to move his. When I trial fitted mine, it looked like I could get away with not moving the radiator though We will see very soon when it gets fitted.
    I couldn't work out how come you never had to move your rad and I did, really had me wondering.
    LOL I just realized why......my engine (and obviously the manifold) are sitting approx 10mm further back in the engine bay because I used the the 3B flywheel and took out the spacer plate between engine and block.
    Mmmm took me ages to work that out, getting slow in my old age .
    Mark.
    Mark - Modded
    • audiman
      • 4827
      LMAO, dont worry Mark, im nearly half your old age and I didnt even think of that!!
      Tom C - www.rcmr.co.uk
      Audi UR Quattro
      Audi 100 C3 2.0 5 cyl 115ps
      Audi B5 RS4 645ps 911nm
      • Mihnea
        • 1288
        #138
        LOL, neither had I. Not too bad for you Mark
        www.MRCTuning.com
        info@MRCTuning.com
        Workshop Directions
        • Doug_RS2
          • 3847
          #139
          I thought we might have welded on the throttle mountings differently.
          I definitely couldn't get it to fit if the engine sat 10mm further back.
          It will run tomorrow - if I can get some PS fluid and coolant. Just a couple of wires to lengthen, turbo oil and water feed to connect and get the bodged exhaust fitted.
          • audiman
            • 4827
            Sounding good Doug, will be nice to see/hear it running. I will phone you later, to see how its going.
            Audi UR Quattro
            • Doug_RS2
              • 3847
              #141
              Mark - have you got a picture of your throttle cable?
              Mine is tight - and I bet that 10mm movement in the engine has helped your cable !! I might need to change mine - unless I can lengthen the standard one. Does it pull through the bulkhead?
              • audiman
                • 4827
                If you know any AA/RAC dudes, they have a cable repair kit onboard the van, they can make it fit by extending it. Call them out saying it broke!!
                Audi UR Quattro
                • auditude
                  • 407
                  Mark.
                  That's the first I'd heard of a spacer plate between the engine and transmission. What was that for and which models had it? Was it for the dual mass flywheel?
                  Thanks,
                  Ken
                  Kenneth
                  1990 Coupe quattro
                  1991 200q20v x 2
                  1985 4ksq 20vt project
                  1986 Coupe GT 10vt project
                  2006 Honda Ridgeline
                  1998 Honda VFR800FI
                  • caterpillar
                    • 2480
                    #144
                    some of the s4 models,who had 6tr tranny had the doublemass flyweel,and a 10mm spacer between engine and tranny.......
                    • Mark Halligan
                      • 2001
                      Doug,
                      this pic shows it fairly well and it is very tight, no doubt it is too short on yours because of the engine being further forward.
                      Mark - Modded
                      • Mark Halligan
                        • 2001
                        Thanks,
                        Ken
                        Ken,
                        yes it is for the dual mass flywheel fitted to the ABY and ADU S2/RS2 engines, I am not sure which other audi models.
                        Mark.
                        Mark - Modded
                        • porkkis
                          • 1994
                          It has been used in only S2 (all models) with 6 spd CGR and RS2.
                          There are 2 different length main shafts in 01E boxes, you know. Unfortunately.
                          I don't even know what flywheel and box combinations require the spacer but apparently the above mentioned. Don't know if they need it with urS4/S6 or newer 01E boxes.
                          • Audi_CQ
                            • 940
                            • Country: Norway
                            #148
                            Are there?
                            The spacer are there because the dualmass are ~10mm thicker, and to get the clutch to sit in the right position to the gearbox(main shaft) you have to move engine 10mm forward(or 'box 10mm rearward )
                            • Billman
                              • 4129
                              #149
                              Originally posted by Wizard-of-OD
                              Also found this interesting picture and thought you guys might like.Its a RS2(same as 3B without the Porsche emblem) that they have simple cut and flipped around.
                              I know you guys will like....
                              p.s. has anyone heard from Corey?I have been trying to get a hold of him.
                              Thanks...
                              Hey people will it not work great? If you see the picture the place for the TB can be adjusted with the metal Hose! I think i might make something like it! Anyone else tryed it?
                              Greetings
                              Go Holset or Go RS4
                              • porkkis
                                • 1994
                                Originally posted by Audi_CQ
                                Are there?
                                AFAIK yes. I haven't got confirmation to this yet, but this is what I've heard.
