I'm still trying to get a price on just such an item. Contact me with your specific requirements as I am designing one at the mo for another member.
K24R Catch Tanks - Pictures added
Right, sorry for the delay on this, seems that snow and popuilarity are a good way of upping lead times
I've finally heard back and hopefully will be able to get these made at teh end of January. If people are still interested then please let me know. Will want a deposit up front to secure orders please.
1994 ABY Coupe - Projekt AlpinweissComment
Hi all, thanks to a new supplier, this is now a go go go!
Prices have gone up a little so a stock tank is now £115 delivered, including mounting hardware.
I can offer a special return pipework set for an extra £35, including a special piece I'm having made up to drop down from the strut brace to head breather pipe.
I'm going to get a prototype swirl pot made up, that replaces the ABY union pipe or 3B rubber item. These are looking like £75 each and should be a great upgrade on their own! Add £25 for the pipework.
A complete kit of catch tank, 'swirl pot' and pipework will be £225 delivered.
Most visible hose can be upgraded to braided hose for an extra £25 / full kit.Last edited by Rusty; 11 February 2011, 17:00.Cheers'en, AndyC
I've had to change my supplier ,so prices have gone up a little... For standard stuff:-
I can supply a vent to inlet tank for £115 and add in the inlet and return pipework for a further £35.
If you want a pseudo swirl pot to replace the ABY union pipe then they will retail at £75 on their own or £100 with hose and clips. This does not require a sump return and so isn't a true swirl pot, however, the larger volume and proper design will greatly improve the situation with oil from the head breather getting blown into the catch tank and does not require the sump to be removed for drilling and the addition of a welded or threaded return pipe.
A kit with both a catch tank and swirl pot, along with hose etc., will be £225.
All hose will be oil resistant and most can be upgraded to braided hose for an extra £25.
Custom stuff based on a stock tank will be marginally more expensive, complete custom tanks will be on a pro rata basis.Cheers'en, AndyC
