I think this kit will have to go on my Xmas list!
K24R Catch Tanks - Pictures added
It'll be tested with a reverse IM, as one of the early adopters has one... Obviously won't bolt up the same but I'm sure it'll fit fine and the 30mm ID pipe is pretty substantial, so will take most of the load.Cheers'en, AndyC
The tanks mount using M8 stainless fixings. The centres are 80mm apart and should be drilled in the centre of the thickness of the bar.
I've not sent off all but 2 peoples' parts Looking forward to fitting this to my car and sorting out the next set of kits tooCheers'en, AndyC
I got the oil separator and new inlet return pipes fitted over the weekend, only issue was the PAS line holder that fits above the after run pump but a little persuasion and all was well. I'll be testing this setup for a while and then moving on to a full swirl pot with sump return.Cheers'en, AndyC
For LHD, I can supply a swirl pot but you will need to find a atch tank and place to fit it.
Dan, I don't supply the hoses, as it's cheaper for you to source them. Swirl pot, catch tank and return pipe adaptor would be around 250 deliveredCheers'en, AndyC
