Problems installing Wagner short intake, need help(+)
  • LHD_Kid
    • May 2006
    • 3697
    #46
    I'm pretty sure it's genuine... and I'm pretty sure I'll get it working. it's just a major hassle.
    you see the rad pipe I've created, also the old wagner one which had rubbed through in 2 places...
    I bought used, not new...
    Edit... the brake servo conversion and electric power steering was much easier than this...
      Hmm, I have no aux rad and no AC so plenty of room.
      Can’t even see the ISV branch from the TB hose on yours..
      • LHD_Kid
        • May 2006
        • 3697
        #48
        exactly. the ISV branch hose is way underneath the rad hose... I'm going to relocate the ISV.... just using some silicon hoses I have spare...
        edit: custom one-off water hose 150 quid from Roose...
        • LHD_Kid
          • May 2006
          • 3697
          #49
          lovely hoses received from the great blokes at Roose.. ISV has been relocated to the area where the PS pump used to be. so much neater then alongside the IM and doesn't use the bad fitting stuff provided by Wagner... will post a pic once completed....
          • LHD_Kid
            • May 2006
            • 3697
            #50
            some new straights and the custom rad hose...
            Sent from my SM-G928F using Tapatalk
            • LHD_Kid
              • May 2006
              • 3697
              #51
              all fitted and running....... it's not very pretty, and the throttle cable looks awful, but I can fettle the looks later.....
              • LHD_Kid
                • May 2006
                • 3697
                #52
                ISV at the front...
                Throttle cable... ugly as hell...
                Custom rad hose fits perfectly...
                  Well done mate, it’s busy with the AC and Aux rad eh ?
                  • LHD_Kid
                    • May 2006
                    • 3697
                    #54
                    Very busy John....
                    Now I have the delights of re-fitting the slam panel (the bottom of which fouls on the new Wagner crossmember... elongating the fitting holes as they don't line up, due to the crossmember moving the aux rad 4mm left...
                    Trimming the plastic trim under the bonnet to avoid the throttle cam catching...
                    trimming inside bumper to get clearance for the IC.....
                    started the car at least... so I'm on the right track
                    Must try and do something with the throttle cable. Can"t live with it crossing the IM like that......
                    • Bowie69
                      • Nov 2013
                      • 2681
                      Couple of P-clip style affairs along the RH side of the manifold to clamp it in place?
                      • sailaz
                        • Oct 2009
                        • 647
                        • Country: United Nations
                        #56
                        Originally posted by Dirtylouie
                        3. No piping included from turbo to IC except for 70-50mm silicone adapter
                        Wagner IC to turbo is 57mm, does it means that back in to 2011 was different ? 70 or 50mm ? Or I don't understand something ?
                        I know thread is about Wagner IM but I quote about IC....
