Exhaust manifold from ebay
  • Dobby84
    • Feb 2011
    • 1169
    I know quality issues have been discussed before with ebay manifolds but I just wanted to see if anyone on here has bought one of these?
    http://www.ebay.co.uk/itm/4006102605...%3AMEBIDX%3AIT
    If so what is it like?
  • Rikki Kitto
    • Feb 2010
    • 6276
    Don't bother sure a few have and chucked em in the scrap bin
    • hunker7
      • Mar 2014
      • 3487
      I will probably get one, clean up casting and try it. Some people say they're bad, some people say they run them for years with no problems. At £80 I'll take the risk.
      '93 Audi UrS4 Avant
      '15 Audi A7 quattro 3.0 TDI
      • imp998
        • Nov 2013
        • 207
        If anyone wants to buy one of those manifolds. I have one £50
        Urs6 avant nogaro
        s2 avant
        • K Simmonds
          • Dec 2007
          • 7633
          I bought one out of curiosity and for an experiment, there's no way I'd bolt it straight on as the casting finish is pretty poor and it will 5h1t debris through your turbo. But it can cleaned it up with a dia grinder in no time, also the holes for the turbo studs are one size too small and need re-driling and tapping out to the correct size thread.
          I blanked them with studs and converted it to T3 flange/bolt pattern which involved removing a fair amount of material which is quite soft for cast so hopefully it's ductile. There just enough to play with to do the conversion.
          Here it is sporting a chuffing great twin scroll K27, I'll be bracing it top and bottom.
          I don't have time now but I can remove the turbo and take some pic's of what I did to convert it over the weekend, it still needs finishing off inside but is 90% there.
          1990 B3 2.0 80 quattro.
          1992 C4 2.8 Avant quattro
          1994 MTM RS2.
          1998 B5 TDI quattro Sport.
          2000 B5 TQS.
          • Kiku
            • Aug 2010
            • 497
            Twin scroll kkk hot side? Wooooot.
            • K Simmonds
              • Dec 2007
              • 7633
              Lucky eBay find, I think it's from a Porsche but can't much info on it.
              1994 MTM RS2.
              2000 B5 TQS.
              • hunker7
                • Mar 2014
                • 3487
                Have any pictures of before/after cleaning up casting?
                '93 Audi UrS4 Avant
                • K Simmonds
                  • Dec 2007
                  • 7633
                  Will take some over the weekend.
                  1994 MTM RS2.
                  2000 B5 TQS.
                  • K Simmonds
                    • Dec 2007
                    • 7633
                    Here we go it still needs a fair amount of work before I'll be happy but it'll give you some idea, I've quickly run a worn out sanding wheel up each port to knock the worst off and they still look pretty rough. Before I started there was loose stuff everywhere. You really need a proper dia grinder and air, a Dremel or such like will take forever, the collector was horrid with a 20mm long burr ready to jump off.
                    1994 MTM RS2.
                    2000 B5 TQS.
                    • mac2226
                      • Jun 2008
                      • 1289
                      I've used one and it needs the casting grinding and tidying up in ports and there was two stud holes that needed enlarging. I think andy10v ran one on his s2 coupe he was the one who told me about this manifold when I asked about it.
                      • Dobby84
                        • Feb 2011
                        • 1169
                        Thanks for the information and pictures!
                        Going to give it a go and use a die grinder as above to clean it up.
                        Do you think it would be worth getting it coated in ceramic or similar?
                        • b4Dan
                          • Oct 2015
                          • 53
                          After a clean up is it likely to flow any more or make more power than a stock AAN Manifold?
                          • K Simmonds
                            • Dec 2007
                            • 7633
                            Yes as it's a direct copy of the Wagner RS2 Evo manifold.
                            1994 MTM RS2.
                            2000 B5 TQS.
                            • b4Dan
                              • Oct 2015
                              • 53
                              So its an £80 version of an RS Spec manifold that needs some grinding?
                              Sounds like a no brainer to me
