Exhaust manifold from ebay
  • #46
    If you can remove the dp from Exaust system then that would be best way as this is how I trial fitted my dp on that manifold and it fitted with a bit of a wiggle then adjust the system to suit dp position.looking at your dp where does it separate? looks like it's touching subframe or it's very very close. All best Michael
    • #47
      Downpipe splits half way down the car. It hits the subframe as it bends up so not sure if it will move forward anymore but will give this a go when I have time.
      • #48
        What a pain
        You could get some spacers made but they'd have to take the heat..
        It would be easier to cut and weld the exhaust than mess with spacers though I reckon
        • #49
          Originally posted by newsh View Post
          What a pain
          You say that but that would involve trailering the car to an exhaust shop as I can't weld stainless.
          I can get spacers made up through work. What temp would be seen, 316 good enough?
          Sent from my Pixel using Tapatalk
          • #50
            Yeah
            • #51
              Will have to get the turbo studs out somehow too
              • #52
                It's going to get nasty...
                • #53
                  Yeah I know, won't be pretty. Maybe the 3b manifold will go back on for now as it all fits.
                  • #54
                    Got it to fit in the end. Still hits subframe but thinking I could raise the engine by 10mm so it clears.
                    White line shows current issue, green shows downpipe/engine raised by 10mm.
                    Not sure if this cause issues with drive line angle....
                    • #55
                      Any major modifications needed? How noticeable is the performance increase over the 3b manifold?
                      • #56
                        Only issue I had was cleaning up the casting finish in the ports, changing the manifold studs and the downpipe issue above.
                        As for performance I do not know fist hand as the car is not driveable at the moment.
                        • #57
                          I don't suppose anyone has one of these manifolds for sale? I have to build a custom exhaust anyways so if one didn't fit right let me know. Thanks.
                          • #58
                            There's some on ebay for about 100$
                            • #59
                              Mine will be up for sale once I sort my new tubular ... I got this and had all the inside cleaned up and I'm running around 350 360hp at moment no issues so I cant fault it
                              Sent from my SM-G975F using Tapatalk
