If you can remove the dp from Exaust system then that would be best way as this is how I trial fitted my dp on that manifold and it fitted with a bit of a wiggle then adjust the system to suit dp position.looking at your dp where does it separate? looks like it's touching subframe or it's very very close. All best Michael
Exhaust manifold from ebay
Originally posted by mac2226 View PostIf you can remove the dp from Exaust system then that would be best way as this is how I trial fitted my dp on that manifold and it fitted with a bit of a wiggle then adjust the system to suit dp position.looking at your dp where does it separate? looks like it's touching subframe or it's very very close. All best Michael
What a pain
You could get some spacers made but they'd have to take the heat..
It would be easier to cut and weld the exhaust than mess with spacers though I reckon
I can get spacers made up through work. What temp would be seen, 316 good enough?
Sent from my Pixel using Tapatalk
It's going to get nasty...
Got it to fit in the end. Still hits subframe but thinking I could raise the engine by 10mm so it clears.
White line shows current issue, green shows downpipe/engine raised by 10mm.
Not sure if this cause issues with drive line angle....
Sent from my Pixel using TapatalkLast edited by Dobby84; 6 March 2017, 13:27.
Originally posted by b4Dan View PostAny major modifications needed? How noticeable is the performance increase over the 3b manifold?
As for performance I do not know fist hand as the car is not driveable at the moment.
