Audi 80 b4 bordcomputer
  • mdz
    • Jun 2012
    • 775
    • Country: Latvia
    #46
    Yes you can. Swap over computer unit to your existing cluster and it will work correctly.
    • mihai_antony
      • Nov 2011
      • 150
      • Country: Romania
      #47
      ok
      in order to be sure, I need to move the bord computer from V6 to the 7A instrument cluster, in order to use the 7A fuel, water, acc instruments
      correct?
      Mihai
      • mdz
        • Jun 2012
        • 775
        • Country: Latvia
        #48
        Swap over that big white part from V6 cluster to your 7A.
        • mihai_antony
          • Nov 2011
          • 150
          • Country: Romania
          #49
          Thank you!!
          • Catalin_BN
            • Nov 2015
            • 9
            • Country: Romania
            #50
            What signal comes from the ECU ? I'm trying to make a BC with arduino and this would be very helpful. Where does this Pin 9 from ECU go? Can I find it in some socket under the dash?
              What ECU are you talking about? ABY ECU Pin T55/9 is the connection to the F96 Barometric pressure sensor. The fuel consumption signal is in pin T55/31.
              REFERENCE: http://www.s2forum.com/forum/showthread.php?t=82357
              • 3db
                • Jan 2015
                • 19
                • Country: Latvia
                #52
                I assume he's talking about MSA12/MSA15 TDi 68pin ECU. Yes, pin 9 is the consumption signal. In Audi 80 it's left unconnected. Go directly to the ECU, it's behind heating box in passenger's footwell. Signal output is square wave with varied pulse width and frequency.
                And yes, it is possible to install OEM board computer in Audi 80 TDi's. You just have to have a 68pin ECU or install one, if you have older one. I have made adapter for the consumption signal, at least 4 cars including mine in Latvia is using it with no problems.
                • 3db
                  • Jan 2015
                  • 19
                  • Country: Latvia
                  #53
