If you get some frames made like Stiggy's then you can custom sort the hole spacings. The Corbeau Forza are damned good seats for the money, more for harnesses than 3 points tho IMO.
Recaro Subframes
Originally posted by stiglet View PostMine are just low enough, not sure if they would be ok with a Corbeau seat and Anthony's freakishly disproportionate body.
Ant91' Coupe quattro 20v - project
KW V2s and other goodies
now gone
03' BMW 330CI - Sold
08' A5 Coupe 3.0l tdi quattro - Sold
57' BMW 525d M Sport Touring
There are some Golf mk.3 subframes for lower seat position, they have the front bar cut and welded lower.Cheers'en, AndyC
Right, got a pair of mk.3 Golf subframes to try and test fit of the driver's side one shows that it fits just fine looks to be about 10mm higher but Recaro also do a reduced height mk.3 subframe. All good since the coupe/80/90 subframe went NLA!Cheers'en, AndyC
Looks like Wiechers Sport do frames for the typ89, B4 etc.
http://www.wiechers-sport.de/index.p...=54&Itemid=131Cheers'en, AndyC
