ur quattro suspension
  • sal_s2
    • 1288
    Sorry Robin, that was a typo, the part number is actually 22 not 33.
    I've taken some pics and will post them a bit later but I've had a good look and everything seems to be fitted correctly
      Did you slacken the wishbone bolts and retighten yet?
      • sal_s2
        • 1288
        Not yet Jon, I'm going to give it a go tomorrow
          Slacken them all off, give it a bounce and roll it back and forward a few times before tightening.
          • twoqu
            • Sep 2003
            • 3103
            #35
            Drat!
            Out of interest did you need to use spring compressors to fit them? From what I remember the H&R's are short enough to not need compressing to fit the mounts. Perhaps someone can confirm this.
            Can't see the shocks having any thing to do with the ride height. It is the springs that determine that. Can't see them settling 50mm either!
            It's certaintly a possibility that they have been mislabeled even if they have the "correct" part numbers on. You might have to remove them again so that you can examine them or compare them with the stock ones. They should be noticably shorter.
            I think that the approval document lists the wire diameter and number of coils but I guess that would be difficult to establish on the car.
            • sal_s2
              • 1288
              I didnt need to use spring compressors, though it was a bit fiddly because the shock tube keeps dropping back down.
              Slackened the wishbones but they werent that tight anyway so they havent made a difference.
              I've taken a couple of pics anyway
              • sal_s2
                • 1288
                Has anyone got a H&R spring for an ur that I could borrow, just to try on my car and compare with my ones?
                • sal_s2
                  • 1288
                  Front
                  • sal_s2
                    • 1288
                    Maybe these will weigh it down a bit??
                    • Corey
                      Banned
                      • Sep 2003
                      • 2793
                      just logged in from the Media Centre in Wales and seen this.
                      Sal,
                      Give me a shout on Monday I should have a spare H&R front spring available at the back of the workshop, you are welcome to borrow it to compare.
                      Corey
                      01636 822288
                      • MarkPS
                        • May 2005
                        • 65
                        Hi
                        Well they are red that's a good start!
                        Your 225/35 tyres are moderate 7mm less in diameter than the std 215/50/15's and a whopping 31mm less diameter than cory's 235/40's, if your's are worn you can take a few more mill off that.
                        I can't help but notice your car is stripped out does it have have the engine/gearbox out as well can't quite tell from the photo, this will reduce the compression on the springs and the car will sit higher.
                        Are you running URQ struts or s2's?
                        Nice wheels
                        Regards
                        Mark
                        88 URQ
                        • twoqu
                          • Sep 2003
                          • 3103
                          #42
                          There is a couple hundred of pounds of interior missing too!
                          See if Corey can measure the free length of the spring he has. That way you can pull just one of for a comparsion. As you fitted them witout compressors it sounds like they are shorter than stock which is encouraging! Stick some of your mates in it to simulate the weight of the interior and see if the car drops.
                          The diameter of the tyres is the same as the originals. So apart from the optical illusion of the larger wheels/smaller sidewall height, the ride height should be 30mm less than standard.
                          • sal_s2
                            • 1288
                            Nice one Corey, I'll try that spring out.
                            Mark, the engine and box are fitted, no exhaust, prop, interior
                            I'm using urq suspension legs etc
                            How did you work out the rolling radius?
                            • Baldy
                              • 469
                              • Home: Sikkim Current: British Antarctic Territory
                              #44
                              heres a nice tyre calc for ya
                              Find information, resources and relevant links for club80-90syncro.co.uk. This domain may be for sale.
                              Nautic Blue UR-Quattro RS2spec ABY20v kkk26/27 hybrid,Bremsport Brake Kit n some other Gubbins.water injection. Mihnea tuned Management The old Bus
                              0-60 4.9
                              1/4mile 13.5
                              • MarkPS
                                • May 2005
                                • 65
                                Hi
                                Tyre Size Calculator - click here or call 01244 813030 for more information
                                Gives the following Diameters
                                215/50/15(STD) 596mm
                                225/35/17(yours) 589mm
                                235/40/17 (Corey) 620mm
                                225/50/15(Mine) 606mm
                                So I think I'm right in saying coreys wheel will stand (620-589)Diameter difference= (31mm/2)Radius difference= 15.5 mm closer to the wheel arch than your wheel tyre combo.
                                It will be interesting to compare the height of the H&R spring vs std spring to see how much shorter it is as I guess they have to allow for less sag when fitted to the car due to the increased stiffness(30% I think)
                                So if the spring are correct and fitted OK you might just need some fatter tyres or 18" rims to fill out those arches or custom springs from coil springs of sheffield (about £175 last time I asked). or find some big friends
                                Regards
                                Mark
                                88 URQ
