S2 Subframe bushes.
  • ristokru
    • Oct 2016
    • 270
    S2 Subframe bushes.
    Hello,
    I will but to my S2 new subframe. No my question is what bushes to but.
    You S2 fans defenetly know what is better options.
    My car is more Daily driver that track car. But firmer handling is always good. But i defenetly dont want to firm and pumpi car.
    Options is to put OEM, PowerFlex and Aluminium ones.
    As i understand then metal ones will rust in salty winter?
    Oem
    • GazzaG60
      • 4133
      id say alloy solid subframe with powerflex wishbone bushes. mines a daily no issues
      • kinaputt
        • Jan 2012
        • 285
        • Country: Norway
        If you daily drive your car, you should use flexible poly bushes (not hard plastic/POM). Rubber is to soft, but aluminium is very stiff.
        • Colesy
          • Feb 2009
          • 2980
          I prefer the Powerflex poly bushes to alloy having tried both, handling wise there was no noticeable difference but the ride was slightly smoother..
            Actually I have Superflex on my Coupe
            Good compromise between stock rubber and Powerflex poly
            • ristokru
              • Oct 2016
              • 270
              Whats the difference on powerflex vs superflex?
                Super flex is a little more flexible
                • piotr
                  • Jul 2012
                  • 1470
                  Power flex are very easy to fit as well,I found OEM to be very difficult without special tools.
                  • shorty_94
                    • Dec 2015
                    • 60
                    If you want to fit OEM bushes, you have to put a screw in the hole an just press on the screws head. Then the bushes will get longer and also thinner.
                    '95 Audi S2 Avant
                    '92 Audi Coupe T89 quattro 2.3E
                    • ristokru
                      • Oct 2016
                      • 270
                      So my options is:
                      Alu. bushes.
                      https://www.akmotorsport.net/shop/al...shings-b2b3b4/ 49€
                      Powerflex:
                      https://www.powerflex.co.uk/road-ser...0mm/11540.html 2x22€
                      I dont know why thet sell front and rear front subrame bushes? Its all the same?
                      https://www.superflex.co.uk/proddeta...=SF080-1797KSS 72€
                      So superflex is double the money. Is they so much better than aluminium and powerflex ones? Also they say those bushes dont fit Sedan and saloon. I dont understand it. All subframes on quattro are the same measurment. Only bold is differnent(10mm vs 12mm).
                      • Mikes2
                        • 1704
                        They probably mean for the rear subframe which uses different bushes
                        Mike
                        http://www.s2-audi.co.uk
                        • ristokru
                          • Oct 2016
                          • 270
                          You mean Superflex?
                          • GazzaG60
                            • 4133
                            depending on the car some have 10mm rear and 12mm front. some 10/10
                            my fronts were 10mm on the saloon. very easy to drill and tap to 12mm.
                            id say the choice is poly or solid then get the best value you can.
                            • ristokru
                              • Oct 2016
                              • 270
                              Solid is 50% cheaper and best value. But i dont want to stiff/bumpi car.
