im having a mate that is working on spring rate atm. and no pieces ordered yet, so i have not calculated the spring lenght yet.
anyone built their own coilover suspension?
the steel threaded sleeve from compbrake starts to crode after a while and your adjustable set up is no longer adjustable . i have mine made in stainless steel not cheap but definetly better .If you are converting the UR struts then you want the 2.5" kit from compbrake. The sleves that come with them are a perfect fit! Just need to cut the old spring platform off dress the strut down and then weld the sleve in place. The top hat which comes with the kit is also perfect for the job!Comment
I read that someone in here is using those compbrake sleeves in Ur struts but I dont know what is ur strut outer dimension? S2 strut outer dimension is 55mm and compbrake specs says sleeves inner dimension is 54.22mm. So if sleeves fit, they are tight at least?
I have a set of Bambridge parts for sale. Let me know if you're interested and I'll get some new pictures.
1976 RD250E / 350LC cafe racerComment
why thank you.
here is the S2Forum version, and lower is the Project Pad version.
http://www.s2forum.com/forum/technical/fabrication/55297-diy-coilovers-aaron-styled
http://theprojectpad.com/viewtopic.p...t=diy+coilover
Thanks all reply.
why thank you.
I have already seen DIY coilovers, Aaron styled thread and I have been also in contact with the A-1 racing. Good thread!Comment
Found some pictures of the struts I ghettto converted many years ago using Compbrake sleeves. I never followed it through since KW had just released the V1 Inox and once I added up the cost of damper inserts, springs, perches, helpers etc was cheaper to buy the KWs and have a much nicer item that won't rust.
CoiloverDIY9.jpgPanthero Coupé quattro 20vt
Imola B6 S4 AvantComment
