Koni adjustable shock absorber settings thread / shocks
This is a sticky topic.
  • Henkjan
    • 1705
    Originally posted by Rusty
    Summary (Coupe):-
    Stock springs
    -1.5F -1.0R
    Where
    -x.x = counter clockwise turns from fully hard (wound in clockwise).
    F = Front
    R = Rear
    any changes to the rear setting in case of a proper ARB? (I have a Whiteline RARB)
    • K Simmonds
      • Dec 2007
      • 7627
      I had a Whiteline rear ARB and an RS2 front ARB, car fully (and I mean fully) Polly Bushed. Think I went for - 1.5 or -2 back and front, was also running stock wheels and 205/55/16 tyres.
      1990 B3 2.0 80 quattro.
      1992 C4 2.8 Avant quattro
      1994 MTM RS2.
      1998 B5 TDI quattro Sport.
      2000 B5 TQS.
        -1.5 turns front and -2 rear (from full hard) was the sweet spot IIRC, some people like the rear harder but I don’t cos it makes it hop at the back.
        • orsum
          • May 2010
          • 1213
          • Home: United Kingdom Current: South Africa
          #49
          Mine are set to -1.5 front and if I recall correctly -2.0 rear. The rear setup feels ok but the front I seem to have a rebound issue. Once compressed the release seems slow and causes the top mount to come slightly out of its perch which cause a knock when reseating. Only during a heavy rise and fall of the suspension.
          I am about to set them to the softest setting to see if it improves the rebound/knocking. Also need to replace the rear dust covers and rear bump stops for some reason they have fallen to bits.
          Driving in SA on good roads they are set ok still a bit hard but I could live with that setting. On other roads that are not in as good a condition they are causing a knocking on the front suspension.
          If it was not for the knocking I would leave mine as I set them.
          Last edited by orsum; 9 April 2022, 05:56. Reason: CORRECTED REAR SETTING AND ADD PICTURES
            • Dec 2017
            • 5991
            I have just fitted mine 1\2 turn off fully soft both front and rear. I am very happy with the result. We have very poor roads around me and it's a good compromise. I have no bounce and the car feels very well planted.
            • orsum
              • May 2010
              • 1213
              #51
              Over the past few days I stripped the front and rear struts and set my Koni shocks to fully soft. Not noticing that much difference except for a slight bit more body roll and a few less rattles
              While stripping the drivers side front strut I noticed the top mount bearing had come away from the mount,
              Lucky for me I had two new top mountings so I replaced both.
