Looks like I will be on the phone ot them in the morning then!!!! Some black thin bushes came with it but no brackets. And a few bolts that don,t look any use but I will find out when the car is stripped!!!!
Cheers JAMO,
Hopefully have it all fitted by the middle of next week.
Dark Grey Avant
RS2 FARB
Alloy Subframe Bushes
My RS2 ARB came with thinner bushes. From a reputable supplier
Used the old brackets, fit no problem. I'd figure that the bushes were designed for the same bracket, as they seemed to fit like the original (ie, bolts all tightened up fully no probs).
Prepare for a much stiffer car, that eats roundabouts.
From memory on this ... The S2 and RS2 FARB brackets are identical. But the RS2 FARB uses the thinner bushes to take up less room under the bracket for the thicker RS2 FARB.
Upgraded FARB bushes are available from Powerflex/Superflex outlets - in S2 or RS2 sizes.
Rear - Neuspeed RARB with the correct upgraded mounting brackets.
Not sure if there is a an upgrade past the RS2 front ARB, not that you really want it on a car with a heavy engine right at the front with a little too much inherent understeer?
Can anyone confirm the sizes of the ARBs mentioned in M Gordon's post.
BTW, can anyone confirm what is the current / available RARB for a Coupe. A friend bought one recently, mine are all Avants.
They also have a 98 B4 Cabrio 2.6 v6, what ARBs can be used on this, if one was so inclined at some stage in the future?
Paul
Well, where I can buy the bushes to put RS2´s FARB? And the Farb?
I will feel the difference between the ABY and the ADU Farbs?
