Originally posted by AndersS2
Whiteline rear ARB
This is a sticky topic.
Originally posted by newshShould be here by NY 06/07 zzzzzzzzzzzzz
what is the longest deliverytime people here at the forum have experienced?
hmm..Anders - S2 Avant Clubsport - 8pots or die!
Originally posted by SkiSo anyone got this on the stiff'ist setting? Im on the middle setting and still struggle to get oversteer.
Cheers,
Roger
Originally posted by 4WheelDrifterAnders? Have you got a Coupé to fit the Whiteline bar to?
I had to wait ~28 weeks for mine.
28 weeks?! sheisse! thats just unbelivable. how long since was this then?
DOH! well, guess i allways could sell it to some coupè owner here in Norway.Anders - S2 Avant Clubsport - 8pots or die!
Cheers,
Roger
Originally posted by Audi_CQI drilled another hole in it(stronger then strongest ) and had to cut off the weakest setting to make it fit.
Personally i'd prefer a larger diameter bar than the whiteline
Avant owners like us have lots more choice in rear ARB's as they are the same as A4 quattro (and S4/RS4). Personally I use a Neuspeed 19mm adjustable rear ARB as it comes with subframe support brackets. There is a thread here about fitting mine.
You can also get bars from Intrax and Quattro GMBH. Intrax do a 22mm fixed bar but from reading a lot of US forums it seems you can wreck your rear subframe with a bar that is too stiff.
Benthe best intentions are fraught with disappointment - gil grissom
