Having spent a few minutes hanging upside down in the footwell of my coupe
I have identified a problem with the clutch linkage. It appears that the joint between the pedal attachment and master cylinder linkage is shot. The rubber (?) bush has worn excessively and the metal cup on the end of the master cylinder linkage has become damaged as a result. Now when I press the clutch pedal down the whole linkage buckles before actuating the master cylinder and it's a real pain.
I have included a picture of the offending part.
My questio is this:-
Can the master cylinder linkage be removed and therefore replaced without a new master cylinder?
If so where's best to get the parts?
If not what is the cure? (new master cylinder?
Cheers as ever for any help.
Andy
![CooCoo](https://www.s2forum.com/core/images/smilies/coocoo.gif)
![Frown](https://www.s2forum.com/core/images/smilies/frown.png)
Andy
