034 Short Shift
My email from Eddy
Hi Campbell,*
It was good chatting with you, pity it was brief.*
With regards to single unit price, you will be looking at £235 + £5 P&P. This includes all taxes, and shipping from the U.S.*
For an order of 10 units i could offer 10% off of the £235 price. This is the absolute maximum i can offer as my margins on JHM products are not great.*
So 10% off £235 = £211.50
I will start a new thread peeps!Comment
Yea some information and pics on the 45 quid one would be great. Its more the play I want to eliminate and a slightly shorter shift. I dont need a tiny stiff change. Ohh err misses.Comment
I'm glad you are interested.
Here's my model foto:
My movie showing how it works on car: http://www.youtube.com/watch?v=pFHSZZZ1LcQ
Tomorrow after traditional Easter breakfast I will put some real pictures.
034 is right across the Bay from me and I'm looking at doing a short shift myself. If it's worth it (i.e. cheaper than your UK 034 source), I'd be happy to be a local go between and then ship over the lot to the UK. Would need someone on your side of the pond to handle local distributions. Busy with a 2 week project for work, but would be available after that to figure things out.
Geoff1990 Coupe Quattro, Full RS2 Conversion
http://www.europeancarweb.com/featur...rs2/index.html
2008 S4 Avant, Sprint BlueComment
so that looks the same as the $110 model from 034?I'm glad you are interested.
btw: here are the instructions on how to mod it to have the reverse lock-out (6 speed box)Comment
I want the cheapest one; This one:
http://www.034motorsport.com/chassis...sis-p-355.htmlso the solid shifter from JHM does not have the reverse lockout?
Doesn't look that short and or solid in the vid really? Or is it just me?My movie showing how it works on car: http://www.youtube.com/watch?v=pFHSZZZ1LcQ
However if it works for my ABY I will buy one as it's really hard to select gears with it at the moment.Comment
That one doesn't indeed.
@ Lloyd, in order to lenghten the throw I had to machine the shaft down (it gets wider on the lower end, limiting the max adaptation in throw) and make a new groove for the circlips. This means my shifter nog comes a bit higher then normal, but at least the throw is now acceptable. If you don't do this, it is undriveable, believe me
