Looking in to rear brake disc options that retain the OEM rear caliper. Should be a very cheap way to add some extra meat to the rear brakes with minimal fuss and total safety. Watch this space...
K24R 300mm / 314mm budget rear brake upgrade
Fecking rear caliper bolt hex rounded on me while trying to remove it... will have a fight with it at the weekend. Got some replacements in the cupboard from one of my just in case orders to Vag Parts way back whenCheers'en, AndyC
Carriers on their way to you... I hope you didn't want me to measure them before they were sent.... coz I forgot....
Complete with fully working sliders...
You will need to clean the rust of them though if you want them to look pretty
ChrisHonda CBR 1100XX Blackbird Turbo....undergoing major changes.....
Ultimot gmbh sells a small kit to use stock rear caliper with 300x10 rotor
Andy,do you know the stock rear piston size?RED Mitsubishi Lancer Evolution VI TME nº 16 of 250
Are you going to space the caliper out?
Irwin do a great tool for those caliper carrier bolts, hammer it on and undo. Has saved me a lot of grief a few times now.
Originally posted by LHD_Kid View PostCarriers on their way to you... I hope you didn't want me to measure them before they were sent.... coz I forgot....
Chris
Sweet, cheers, I'll look that up.
Not measured the rear piston size but will do so. Surely the informatiojn is on here somewhere?
I haven't found a 300mm disc that's suitable but have found some in the 275-290mm region, which require minimum modifications to fit. I'm going to try the smaller end of the scale, as there are 2 identical hat discs that are at opposite ends. The idea is that you buy some discs, brackets and maybe a tiny spacer for behind the disc and it's all bolt on with no fuss.
I have also found some suitable 12mm discs that I'll be looking in to once I get the carriers off ChrisCheers'en, AndyC
http://ultimot.de/Komponente.php?id=BK020&TypWahl=006
302mm discs are fitted to some A6s but the hat height is all wrong and they're 12mm thick, not 11mm, so I wonder if that's the same disc...Cheers'en, AndyC
