Any interest it C4 adjustable camber/caster plates?
So is there any interest in adjustable camber/caster plates for the C4 chassis(UrS4/6, 100, A6, etc.)? The idea is to make a quite simpple solution to keep the costs low, at least lower than on the 2bennett plates. Should work with stock upper spring plate, but will have a uniball bearing. As large adjustments as possible for them that use narrow springs diameter/coilovers.
I'm supriced no one is intersted in these..? Hope the get protos ready in few weeks.
Wow, I don't see a price anywhere, are they even available? Ed didn't get them ready... Either way CNC-machined versions would be too expencive in the end.
Ed's are not currently available as far as I know, I would buy a set but I just picked up a set of 2Bennetts used for cheap. I'll put a link on QW and see if anyone over there is interested.
the spherical bearings on 2B camber plates is noisy.i remember a lot of folks has no such noise problems on them but mine.i ended up replacing them for a couple times and the noise is back soon.if you track the car the noise ain't your problems then beside of noise problem,i'm happy with them.
I understand. It would need a totally different style plate with the stock top bearings and rubber bushings, but I will look into it, I may have an idea of how to do it. These spherical bearing plates will always be noisy, at least when the bearing get some play in it.
