No what I know of. If you can measure the bolt pattern of the top mounts, then I can check if it's the same as C4. Just measures from bolt to bolt(3 studs that fit the top to the chassis).
I have now new design on these camber/caster plates. Possible to adjust caster alone without camber, and also possible to adjust positive camber. Will add some pics when I get them coated.
