Camber ~20mm. Couldn't feel any difference at all compared to stock top mounts.
Any interest it C4 adjustable camber/caster plates?
Not sure yet, 140-180e/pair..? Have to see how my friend resolves the needed bushes for the shock fitting... it's diifferent from the C4 chassis.
Bambridge style upper spring plates are recommended. Other wise there will bee clearence issues between the spring plate and camber plate.
These kind of flat upper spring plates are not recommended!
Cool, I will keep an eye on the thread.
I was going to ask if you made the bush for shock-bearing.
What did he make the top mount support from? Large pipe?Current-2004 Impreza PPP wagon
Sold ABY-stock
Soon available 4 kits for coilovers and 2 kits for standard springs.
One of both are reserved.
Originally posted by lucidmatt View PostI have PayPal standing by if this batch is ready... (totally serious)
All kits for stock springs are sold out atm. I had only a short testing with big springs and forgot to take pics of it. But one guy here locally are now going to test them more and compare them, if they rise the suspension, and how much in that case. I don't wan't to sell more of these before more testing is done, other wise it can get too expencive for me if I have to sent out second gen parts to fix problems, if there are any.
A guy from our finnish forum have now installed the camber plates for big springs, and have measured before and after. They seems to rise the front by 20mm. I was expecting something like this. He's going to cut the lower spring plates and weld them 20mm lower.
I have no issue with my front being 20mm higher as I have adjustable spax rears so can tune the height at the rear to match.
I wonder how the wheel looks in the arch when the caster is set near maximum? Do we need to do something to adjust the bottom mounts to move the subframe forward? Is there room for offset subframe mounts? Or even something to move the role bar forward or modify it at its end were it bolts to the bottom arm to move that forward?
Sent from my SM-G900F using Tapatalk
