Any interest it C4 adjustable camber/caster plates?
  • As told in this thread before, the camber plates for normal springs will rise the ride height by 20mm. I found some old pics from my HDD that shows how simpple it is to lower the spring plates by 20mm on the struts so you can keep the same stance as before. Just carefully cut the lower spring plate loose and weld it back on in same position but 20mm lower. Quite easy job when you have the struts out.
    And if you use Bilstein HD "upsidedown" shocks, then remember to bore small water drain holes in the bottom of the strut.
    Sometimes also the tie rod end can be really hard to get off, this is my HD tool for it , it keeps the rubber intact.
    • Did you make that tool Thomas? They can be a real pain to pop.
      • Yes it's DIY, quite old tool. Did it about 10 years back for my typ44, but it's still good for the C4.
        • I'm interested in a set of plates as well when they're ready.
          EDIT: That's embarassing. Totally necrobumped this thread. Wrong thread.
          • Originally posted by pilihp2 View Post
            Thats something i havent heard before
            • Originally posted by Thuppu View Post
              Hello,
              is that modification with cutting, lowering and welding back them spring plates a safe thing to do ?
              Never seen something like that anywhere else.
              Thanks.
              • Originally posted by silnor3ki View Post
                Hello,
                Thanks.
                Well I'll guess this will depend on how you classify your welding skills. If your welding usually looks like this, then it could be a good idea to don't do it.
                • well I did not mean that
                  sorry, I did not specify my question properly.
                  if you lower the spring plate, will the suspension still work properly ?
                  I assume only with some good lowering springs otherwise it would be to soft (and by doing that to spring plate also to low) and the bottom of the car could bounce off the street in some cases. Am I right ?
                  • If you think about it, the spring will only be ~20mm in different position(lower down) from stock, nothing more, same spring travel left. C4 chassis can't really hit the ground, the shocks will bottom out before the car "floor" hit the road. Of course there can be ground contact on bad bumps or pot holes, but anyway you don't wan't to drive fast on those and propably destroy your wheels.
                    There really isn't anything fancy about doing this. Making coilovers is then little bit more complex...
                    • I need info on these plates
