If I remember, tomorrow I will snap a pic of the wheel in the arch, I adjusted full caster. With coilovers it's more than you could use with big springs.
Any interest it C4 adjustable camber/caster plates?
Have you had any issues with the wheel rubbing the back of the arch?? My winter tyres are 225 50 17 and are very right to the rear of the arch and have left some slight marks on the plastic..Comment
Seems like these 245/35 19" tyres slightly rubbs the back of the inner fender when you turn the wheels. I don't now remember the offset of the wheels, maybe 35 or 40, but I use 12mm spacers.
Well, our tyres are a bit oversized though.
BMW 740iA e38 - ProjectComment
Yes,Thomas 245/35R19 will be slightly rubbing rear of the wheelwell when turning full lock to lock.
235/35R19 is the best number if you're supposed to be running on 19" Rims.I'm running rear 265/30R19
and had tried to swap them to the front.It wa salso rubbing but less than 245/35R19.one of a few I5 from Asia.Comment
Is there anything that can be done to move the wheel forward at the bottom like moving the subframe forward on offset mounts.Comment
I would be interested in a set of bushes bored offset and also your top mounts for big springs. Pm me a price. I already have your subframe mounts so don't need new bolts.Comment
No, I havn't those ready, need to be done. How much offset would be ok? Something like >14mm could be done on your current bushings. Just bore new holes and tap the steelbushing holes.
I need to look at them again. Is there room to redrill and tap existing ones. That would be good.
The more caster the better??Comment
Yes, there is room enough.
That is what I have heard, I have no experience about it yet.
Have these been tested on a T44 200 yet? I need a set bad for my 200 20v.'15 S3
'91 200 20v
'91 200 20v AvantComment
