One paintable set for me, please!
Carbondesign RS2 lower door trims
Lower Door Trims in carbon
aRtis.. we "All" need to accept that the lower door trims will never be the same as OE .. you need to design and make to suit the material used (Carbon) .. what i am saying is so long as these carbon trims look to be designed to do the job and look good when fitted, with nice radi on edges with no crazy gaps & they maintain original door shut lines .. made in carbon they will probably look a lot better that the original door trims which in my opinion are not wonderful in Audi OE design.
You can see by the thread responses ..there is much demand .. I expect into the future these new exterior carbon door trims will become the must have upgrade on the RS2 worldwide..to ensure you a good profit.
Maybe by spring 2017 i can have a set, you could even pre-paint them for me in Polarsilver as part of your design & development trial!
Best Regards. Polarsilver.Comment
Thanks for explanationaRtis.. we "All" need to accept that the lower door trims will never be the same as OE .. you need to design and make to suit the material used (Carbon) .. what i am saying is so long as these carbon trims look to be designed to do the job and look good when fitted, with nice radi on edges with no crazy gaps & they maintain original door shut lines .. made in carbon they will probably look a lot better that the original door trims which in my opinion are not wonderful in Audi OE design.
I am personally interested in new carbon set. Following first kit will be put on my RS2 (obviously bluish carbon), then we evaluate and offer. Perfect fit and placement will be the biggest challenge.
ArtisComment
I'm also in for a paintable set.
Thanks for the effort!Comment
