Forum Running Slow
yeah I think there are a few in the same position with load times or partial page loading as I have sometimes. All seems very random as to when and where it happenssigpic
1992 3b S2 CoupeComment
Have also bad issues with my mobil. Usually helps when you refresh the page a few times. After 2-5 times the page usually loads complete...
BMW 740iA e38 - ProjectComment
I did a little digging on this. It seems that on a mac, there is an issue where it is looking to see if the browser is actually tapatalk app, causing an error and thus slow loading, if any at all occurs. It may be worth disabling tapatalk for a test...?Comment
I think Sonic tried disabling the tapatalk plugin - then tested on iphone browser - he found no difference. Thats as I understand things but could be wrong.
Cheers,
PaulPaul Nugent
mmmm - Mac OSX and iphone are essentially unix/linux under the skin so that is interesting. Maybe some one of the plugins in our setup has been 'optimised' for windoze to such an extent that it impairs performance on other operating systemsPaul Nugent
It's probably some issue with lower network layer, like IPv4 vs. IPv6, server packet sizes, ACK, whatever stuff.
I noticed a speed increase when I disabled IPv6 support on my Mac, however under Windows it's speed off lighting fast compared to Mac running IPv4-only support.Comment
All relevant parties,
I know I'm not paying customer and the forum is voluntary, but the forum has been unusable on my two iMacs, iBook and iPhone.
Cold turkey has now turned to dispondency and depression, so anything you can try / do to fix the problem would be great.
All other forums and websites still work fine on the above kit.
It all started when the change of server was flagged about two months ago.
Only able to post this by using someone's PC, where the forum works fine. Can't work the spell checker on a PC.
I am sure it is not just myself who is an apple affected person.
Thank you for reading this post.
No point in posting a wanted request for S2 Avant ABY rear brake calipers as I won't see the replies, but if you have such items you could pm macandmar?
Or would someone have B7 S4 Rear discs and calipers for a '95 S2 Avant?
Many thanks.Comment
i wouldn't be supprised if some of the problem isn't down to the iphone as well, my iphone is c**p at the moment it crashes all the time and it all seems to have started when i did the latest softwear down load for it which was about the same time the forum started playing up for me on it.never set your expectations to high that way you are never disapointedComment
I have almost given up on this forum, seriously, is anything being done to resolve the issue of completely & uselessly sloooooow page rendering which has been occurring for the last several months ?
I've run Mozilla, Chrome and Safari on my i7 Intel iMac, Mac Pro & Powerbook Pro with no difference, the only machine which now still loads the forum norally, is my work XP windoze box.... and that is the last place I'm trying to view the forum...!!!
What gives already ???? :-/Comment
