Audi 80 Saloon S2 nearly finished!
  • #46
    Originally posted by UR-S4 View Post
    I know about the differances the question was how did you adapt a 6 cyl to accept a 5 cylinder engine.
    remove the v6 alloy mounts(just undo the 2 or 3 bolts on each one from inside the inner wing) which leaves a nice clean area to weld on the steel 5 cylinder ones,either cut them off another car or i do believe you can still buy them new
    there are some better pics somewhere of the engine mounts,but here is one that was done
    http://www.nogsport.co.uk/modules.ph...er=asc&start=0
    • #47
      thats how i did it, its the easiest way. i bought the mounts new from the dealer
      Pete
      Audi 90 Quattro (typ B4)
      AAN swap in progress
      • #48
        went to santa pod last sunday and did 4 runs . very slippy like ice but managed a 12.6 @115 mph.
        new turbo this week so will let you know what the new time are when i go next.
        link http://www.youtube.com/watch?v=RX1g-nCoBbU
        • #49
          how did you get on with the gearing this time?
          • #50
            8 mph up on my terminal speed so much better. you need 900bhp to use the diesel box i rekon
            i put a rs4 b6 box in with the oil cooler in the end and it works really well
            • #51
              good to hear, when's it getting mapped with the new turbo? interested to hear what the difference is between the two housings as the one that was on it when you took me out was mental.
              • #52
                i will talk to Doug @ MRC and see when they can fit me in again for a map tweak and then back to pod see if we can crack the 11s
                • #53
                  Managed to do a 11.05 @ 127 mph on saturday at santa pod!
                  into the 10s is my new target for this year.
                  • #54
                    more pics soon
                    • #55
                      http://www.youtube.com/watch?v=PdTn5DnbwFs
                      Chef
                      • #56
                        thats the run cheers pal couldnt find it myself im rubbish with youtube.
                        what it didnt show is the next run my diff explodes on the line when i tried a 7000rpm launch
                        its ok i have a couple ofspare ones
                        • #57
                          quite logic when the title says COUPE quattro
                          • #58
                            wich how many horse power???
                            • #59
                              roughly 550-600bhp depending on boost level
                              • #60
                                Originally posted by quattronutter View Post
                                most important question is when do i get to go for a ride
                                Get in line, I wanna ride shotgun
                                Stunning progress on this beast, saw it in construction and it was so impressive
