(steel ) crankshaft sprocket
  • my2000apb
    • Jul 2010
    • 637
    Originally posted by volcano rs
    yes they are still available do you want standard size or for wider belt ? i can ship to USA .
    not sure, i have a us spec 3b from a 200 20v
    BEAST '90 CQ 24v VRT / O1E / v8 rear, HOLSET SUPER 40 http://www.theprojectpad.com/viewtop...1&t=193#p37887
    DD '86 4kq BLAZE, swapping aba/16vT and O1E http://www.theprojectpad.com/viewtop...1&t=201#p38264
    • volcano rs
      • Jun 2005
      • 2265
      thats just standard size. i should have them end of the week
      • volcano rs
        • Jun 2005
        • 2265
        Originally posted by terrybullwon
        Got any pictures of the wide belt one Jamil?
        same as standard just around 4mm wider thats all. i,ll post a pic tomorrow.
        • my2000apb
          • Jul 2010
          • 637
          cool let me knwo when they are availible
          • volcano rs
            • Jun 2005
            • 2265
            will do
            • volcano rs
              • Jun 2005
              • 2265
              here is a pic of the two types of sprockets.
              i also have 6 more standard size sprockets in stock now.
              • volcano rs
                • Jun 2005
                • 2265
                due to people asking for these i have 4 sprockets available.
                  Originally posted by HPmuirt
                  Hey Jamil, I assume the 25mm is for the RS2 width belt? Si
                  Since when was the RS2 cam belt wider than the AAN or ABY cam belts?
                  Here is a photo by somebody here of AAN (top), 3B (middle) and RS2 (bottom) cam belts. Look the same width to me.
                  • volcano rs
                    • Jun 2005
                    • 2265
                    can you see any where i said the belt is wider ?.
                    i had some sprockets made wider in case people want to use a wider belt of some sort which i'm going to use on my stroker project for strength. get your facts right !
                      And did you see that I DID NOT quote *you* in my question but someone else ( HPmuirt) ?
                      Learn to read.
                      • porkkis
                        • 1994
                        The wide belt is used in VW 16v and early 1.8T 20v engines. The 16v cam wheel can be used in I5-20v but it does not fit under the timing belt cover. The tooth profile is the same.
                        Also tall block 5cyl diesel and 2.5 petrol engines use the wider belt but with different tooth profile (more square like in the old 5cyl audi).
                        Can't remember just now what water pump should be used in I5-20v with the wide belt. Anyone?
                        Actually I think 3B water pump has wide enough pulley to handle the wide belt.
                        • volcano rs
                          • Jun 2005
                          • 2265
                          thanks for the info porkiss
                          • my2000apb
                            • Jul 2010
                            • 637
                            do you have any of the wider ones in stock
                            • volcano rs
                              • Jun 2005
                              • 2265
                              i might have one i'll check for you later .
                              • my2000apb
                                • Jul 2010
                                • 637
                                thanks this will be perfect for my 16 valve stroker project
