OUSTANDING: 12
John Cryn – x 2 - AAN & 3B
Matthew Combs – MC/7A/3B
Jared Hersh x whatever
Aurimas Radisauskas x AAN
Dace Voit
Anton Churaman – 3B
Lou Cacaj – AAN
Ronald Vossen – 3B
S2forumuser – jade x ADU
S2forumuser – jsw3 x ABY
S2forumuser – thuppu x AAN
Depends on where the dry sump pulley is mounted. Behind the timing belt sprocket? Yes
on the crankshaft nose? yes
The centre will be exactly as it was with the OEM.
Will the diamond washer will be needed to assemble the stuff?
I will be suopplying the EKGrip shims that come standard on the newer motors as a measure but considering the timing belt sprocket is one with the fluidampr , you will not be needing anymore washers.
