@Twoqu - not sure I understand the concern about tabs on the pads. It doesn't look that different a pad shape than stock S2 rears...
If the 8E0 carrier wraps around the 8E0 disc and uses the 8E0 calipers and 8E0 pads then all will be grand and compatible. It will be a massive fluke if it turns out that easy. I'm preparing myself for custom made carriers !
@Stick - I'm not anti Ford parts really. Hey I drove a Mustang for three years... Surely that says something. I rather doubt that the Ford Scorpio 300mm vented disc will fit the S2... and its even more unlikely the Ford carrier will be useful but for sure they may have used different varieties of rear Girling calipers that could have uses. Don't forget all my intentions here are for the Coupe, but the Avant has a different rear caliper 'cos the handbrake mechanism is different - some abnormal sources of calipers could be useful for the Avant folk.
Anybody know if a Girling catalog is available - on line or in print ?
Paul
Paul
I also confirmed the mad 145mm caliper bolt spacing and the bolt threads are same as normal there too.
