@Paul,
Be strong, it's always hardest to go first with these projects. It doesn't help that you have to work on the drive and no one else is around for inspiration.
Maybe we should gather a team together for a project weekend to work it all through and sort out the cables or look into it next time you over this side of the water. If we had it in the air we could have a clear view of what's best and whipping the exhaust off would be a quick job.
@Twoqu
Electromechanical calipers don't have cables as they have electric handbrake mechanisms (which I'm sure you knew already ). Would be a lot of work to convert to them though as they have a control unit that works out pad wear etc to keep the pistons in the right place. Also have to be put into service position via diagnostics computer ( or VAG-COM) to change pads etc as you cannot manually wind back the pistons.
The release is very slow on them as well. My boss has a new Passat and it can take 5-10 seconds for the handbrake to release after you push the button.
Ben
@Twoqu
Ben
