8E0 Rear Brake Upgrade
This is a sticky topic.
  • S2 Ant
    • 3682
    what part number have u got and i'll find a price if thats what u need
    Ant
    2011 Kawasaki Z1000
    • twoqu
      • Sep 2003
      • 3103
      #107
      Ant,
      Jamo posted 4D0 615 323E
        #108
        Which is weird cos I'd expect last three digits to be 423 and 424 !!!!
        Is it worth considering RS4 (2.7TT) for a right sized caliper with handbrake on the side ?
        Darned again if Google will find me any pictures....
        To heck with this - I need sleep
        Paul
        • twoqu
          • Sep 2003
          • 3103
          #109
          Agreed! Till tomorrow!
          But the 423E is the older S8 style Lucas caliper.
          Pretty sure the RS4 has botom pull
            #110
            Right then... Looking at the family album now with a happy face !
            The MY03 onwards rear calipers on the A8Q are deffo the electromechanical handbrake jobs so they are out of the question.
            BUT - On the MY02 A8Q there is an option for 310x22mm rear brakes on the armoured limo. And guess what - they call up Girling calipers - and the imagery depicts a side access handbrake.
            Caliper numbers are 4D0 615 423E & 424E
            Now of course the tricky bit is to wonder they have the right bolt pattern to work with the 8E0 carrier which is sized for the chunky TRW caliper.
            So then you get to wondering if you need the A8Q carrier = 4D0 615 425D
            Which is fine until you remember that is sized for 310mm diameter and so might not work with the 8E0 300mm disc...
            So then you wonder how close the dimensions of the A8s 310mm disc (4E0 615 601K)will be to the S2/8E0 application...
            And then you realise that life is just too short
            Paul
            • S2 Ant
              • 3682
              Paul, too many options, decisions decisions!!
              Ant
              2011 Kawasaki Z1000
                Originally posted by twoqu
                Ant,
                Ooops think i did a typo!!! i will post a pick when i get home
                • twoqu
                  • Sep 2003
                  • 3103
                  #113
                  Paul!
                  ******! The 423/424E are the S8 Lucas alloy ones so not compatable with the TRW carriers. The top hat on those 310mm are 43mm so too deep.
                  Right, what we need to do is discover what other vehicles use this type of caliper. It would be ideal if VAG had a candidate. Still think its worth looking at the bigger VWs if they have 22mm rear discs. So perhaps its worth one more look!
                  Other than that we shall have to stick our heads under likely candidates. Will have to be larger vehicles, VOLVO perhaps?
                  • Ski
                    • 2591
                    #114
                    my rear brakes have melted for the 3rd time since ive owned it, Im looking at a possible rear upgrade.
                    ABY Coupe
                      Sorry guys my bad typed wrong number
                        #116
                        Another option looks possible - using VW Phaeton rear caliper. The largest rear disc option (335x22) on the Phaeton calls up what 'looks' like a TRW caliper. Part number is 3D0 615 423A & 424A. Apparently these are black in colour.
                        Anybody seen under a Phaeton recently ?
                        This only applies to the largest rear brake option. The two smaller sizes of disc (280x22 and 310x22) look like they are using Girling calipers, but I can't be certain.
                        Paul
                        • WabTheKing
                          • May 2004
                          • 2567
                          is 335 not a bit big for the rear? think this might have a knock on effect unless your are going to alter your brake bias,
                          last thing you want is the back locking up before the front
                            365 Phaeton upfront 335 Phaeton on the rear, sounds good to me!
                              #119
                              Yeah, pointtaken but I'm just interested in the caliper... Cos if the bolt spacing and handbrake cable is correct it will work with the 8E0 (300x22) disc and its carrier that bolt so beautifully onto the S2.
                              Paul
                              • WabTheKing
                                • May 2004
                                • 2567
                                ahh see, furry muff mate
