My s2 avant STEP 1
  • Billman
    • 4129
    #601
    Originally posted by AndersS2
    Goal is 1,5 bar boost and a reliable engine with some extra puff. Some theories of what that'll make on the dyno?
    What turbo again?
    Sorry if it is mentioned but what rims are these? Typical S2 painted what?
    Go Holset or Go RS4
    • AndersS2
      • 1364
      • Home: Norway
      #602
      Originally posted by polishing_frenchman
      Anders ,everytime i read your posts it costs me money wheel colour looks stunning against body colour and of course the brakes more pics asap
      Lol, if it does help a bit, it cost me quite a bit too.
      Thanks anyways
      Originally posted by AndyP
      I used AMG Mercedes E55 discs for an 8 pot conversion and they were both the same. I tried to take them back and they told me they were supposed to be like that Not sure if Audi are the same though.
      hm, I hear you. I will talk with audi myself and post back when I got some more info.
      Cheers Andy
      Originally posted by geryS2
      definitly the best car on this forum !
      great pics, will try to upgrade mine to some same specs, really perfect !
      Kind words there!
      Originally posted by Frusciante
      I agree!Example and target for my project
      Cheers!
      Originally posted by Lighthouse
      Hi Anders!
      Did you get an answer on what the pins that came with the DBR cam gear pulley was ment for?
      I did not do anything more about them other than saving them. One thing to do is mailing Dahlbäck Racing to confirm what their function really is.
      Originally posted by Billman
      What turbo again?
      Turbo is the old 3076R and wheels are the one and only mk1 avus 18"
      Anders - S2 Avant Clubsport - 8pots or die!
      • AndersS2
        • 1364
        • Home: Norway
        #603
        Got the height on the suspension set finally! Ended up with the front adjusted all the way down. So no option in going lower there.
        Rearwise I had to adjust upwards, ending up with 50-60mm left of threads. Makes no sense to have so many threads left rear and none up front, height beeing equal. All wheelwells -> top of wheel measure 65mm, and got plenty of room in horizontal wheel movement (not that it should be any problem by how stiff these Clubsport coilovers really are).
        Exhaust system need a tiny weld/change angle to compensate for the engine moving further back.
        Only missing Breitling and his fluids (lol), brake fluids that is. Next time im home its clutch and brake -bleeding time, then a drive w/camera?
        Also in the process of ordering ECU. But which one to go for? Not sure the Autronic SM3 supports the 034 high output coils w/drivers, anyone who can confirm that?
        Heres some mandatory pics you lot want. Dirty/dusty pics
        Mocking up the exhaust, check out the rearwheel camber:
        Final height adjustment done:
        Front is mounted once mapping is done:
        Thats all for now. More beer please
        • quattrostyle
          • Oct 2006
          • 6229
          • Big Lee M
            • 2571
            The car sits spot on! Bet you can't wait to get it back on the road. It will be worth the time you've spent on it.
            Just some finishing touches to do now
            • AndersS2
              • 1364
              • Home: Norway
              #606
              Originally posted by quattrostyle
              Enjoying 24 stella artois now! Plane leaves at 0900 tomorrow. No worries!
              I agree, but i suspect a little more adjustment need to be done once the coilovers get driven in. We'll see, but yes, Im really eager to take it for a spin
              cheers
                Anders what is the paint code of your car?
                • AndersS2
                  • 1364
                  • Home: Norway
                  #608
                  LC5U if I remember correct. I was told there was some additonal flakes in the paintmix (by the previous owner which did the repaint)
                  Go Blue jamo!
                    Ah so thts why it looks so nice
                    • europeanme
                      • Oct 2005
                      • 3817
                      Go Blue jamo!
                      Blue is the new black!!...
                      • Bram
                        • Aug 2006
                        • 2582
                        awesome Avant. Me like
                        • AndersS2
                          • 1364
                          • Home: Norway
                          #612
                          Cheers for great comments guys!
                          You are the best
                          Not much to report on this project these days. Ecu and new injectors are on its way. Supposed to be here on monday, but then im off to work in the states for a few weeks, so have to wait untill next time to drive the damn coffincarrier.
                          I also know its crazyness, but Im toying with the idea of add an half inch to the avus wheels in order to make them 8,5" wide. That have to cure the lack of width which I miss now, compared with the lm reps I had earlier on. It shouldnt be any problem adding the extra 0,5" on the inside of the wheel, as there is enough clearance there.
                          8,5" is perfect fuction/form on the avant with 225/40/18 tyres, and I miss that to get it perfect on this car
                          Remaines to see if I go bother with it. Cool thought though.
                          Im also in the process of bidding on a set of Recaro Pole positions in carbon. They would do the final touch in the interiour -function wise, but also regarding the looks. Always wanted a pair of those ever since my first drive on a track with the oem s2 seats, as traveling sideways inside the car isnt that much fun when going fast. Also rs2 recaros dont grow on trees anymore.
                          Pic:
                          Do you guys have some recomendations on oil? I want to go thicker than the castrol 10-60 as this is not a racing car, but a "sportscar", so thinking maybe 5-50 synthetic? Any experiences on this? Winter no problem as It wont be used then.
                          • RS246
                            • Dec 2005
                            • 98
                            • Country: Norway
                            #613
                            Nice ride mate !
                            Are you going to Våler VACN in June ?
                            • AndersS2
                              • 1364
                              • Home: Norway
                              #614
                              Originally posted by RS246
                              Nice ride mate !
                              Cheers for that.
                              No can do. Got work to do.
                              • EspenW
                                • Apr 2007
                                • 1534
                                • Country: Norway
                                #615
                                Do you guys have some recomendations on oil? I want to go thicker than the castrol 10-60 as this is not a racing car, but a "sportscar", so thinking maybe 5-50 synthetic? Any experiences. Winter no problem as It wont be used then.
                                Mobil1 5w-50 Rallye Formula.
                                Often on sale for a decent price at Smart Club, COOp, etc.
                                1994 80E Avant
                                1986 2L Golf 2 on Alcohol
