1995 Audi S2 ABY Ming Blue
  • steverrquattro
    • Oct 2006
    • 788
    I guess the rocker cover gasket has gone. Ordered a new one today along with the RPM sensor, oil, oil filter and air filter.
    Steve
    1990 RR 20V
    1982 SWB UR - RS2 Engine
    • LSG
      • May 2010
      • 897
      Flipp eck you don't see that to often I'm happy to say. I guess that's why you should always service a new car so things like this show up. Hopefully not to expensive, just time. Good luck regards lynn
        Make sure the crankcase breather is not blocked
        • steverrquattro
          • Oct 2006
          • 788
          Good shout. I noticed this in the intercooler as well.
          This gallery has 1 photos.
          Steve
          1990 RR 20V
          • steverrquattro
            • Oct 2006
            • 788
            I'm now down to 5 fault codes. Changing the sensor now pulls in the relay and we have fuel at the spark plugs, but still refuses to start.
            I'm ignoring the first four and want to concentrate on 00532.
            01257 ISV
            01247 N80 Solenoid Valve
            01262 N75 boost valve
            00513 RPM Engine speed sensor (Just replaced)
            00532 Supply voltage
            With reference to 00532, it says poor earth connection to J220. What is J220?
            PS I've had the wiring off the inlet manifold and cleaned all of this up.
            Steve
            1990 RR 20V
              01257 ISV
              J220 is the ECU
              Check the connector for pins pushed back
              Meter from the connector to chassis to be sure all the grounds are good
              • AndyP
                • 6049
                Are you sure that battery is OK? I know it was turning over OK, but the battery was showing less than 12v.
                • steverrquattro
                  • Oct 2006
                  • 788
                  I took the one off the red car which started straight away this morning and it had no effect on the S2.
                  Whilst checking the earths again on the IM, the one for the coil packs was VERY loose and the bolt had not even been tightened up properly, in fact there was a gap of about 3mm. Plugs are now saturated in petrol, so I've left them out overnight and will come back to it tomorrow.
                  Steve
                  1990 RR 20V
                  • AndyP
                    • 6049
                    Looks like there are a few earth connections for the ECU
                    • steverrquattro
                      • Oct 2006
                      • 788
                      I swapped the original plugs back from the SWB and noticed that these were a lot deeper. The 00532 code has now gone and I'm left with:
                      01257 ISV
                      Engine turns over and on occasions almost fires and then it momentarily stops turning and then starts turning again which I find odd.
                      All x5 off plugs are saturated in fuel when I remove them, so I am now thinking that it is ignition related. Might be worth noting that it is running the TFSI coil setup.
                      Steve
                      1990 RR 20V
                        Is the ground on the coilpack loom connected, it usually ends up on one of the cam cover bolts.
                        As far as codes I reckon all three of those other devices share a ground on the IM.
                        Are you using Vagcom? If so you can do an output test to see if they click.
                        Engine speed won’t go away till the engine starts.
                          Pull a plug and lay it in it’s coilpack on the cam cover and crank it over, you should see a fat spark.
                          • steverrquattro
                            • Oct 2006
                            • 788
                            Tried it today and no spark which explains why it is not starting. Weirdly as well whilst I was changing the rocker cover gasket, the alarm went off, then the indicators continued to flash for a minute or so after the alarm stopped sounding???? The car doesn't have an alarm fob, so I am getting really confused now.
                            Just installing VCDS on the laptop and will try my new lead shortly.
                            Steve
                            1990 RR 20V
                              Right so it seems there is an old alarm install that needs to be traced and removed. Time to look under the dash for wires connected to the back of the ignition switch and to the ECU loom on the passenger side.
                              • Colesy
                                • Feb 2009
                                • 2981
                                01257 ISV
                                Have you checked all the fuses? With multiple fault codes could be the cause. Had similar in the past when the faults were all on the same fuse.
