91 Coupe
    • Dec 2017
    • 5992
    Originally posted by LSG
    Yes you should run coolant to the Turbo it will get to hot and damage the turbine housings if you don't.
    Agree. Some early turbo's didn't have water cooling and they didn't last as long and you had to run the engine for 3 mins before switching off! However, some turbos still only rely on oil cooling and seem to work ok (Holset). Has it got an aftermarket turbo?
    • LSG
      • May 2010
      • 897
      On all the turbo bikes at big cc racing we only use oil the turbo is a blow through set up and sits at the front off the bike by the front wheel so air gets to it. The turbo on your car doesn't get this luxury so will get very hot very quickly. Hence needing water to help it.
      • Lopez90
        • Oct 2019
        • 119
        • Country: Norway
        #48
        alright the previous owner used other setup on the car, without watercoolant, so i guess he has blocked it.
        cant seem to find the water hose with the banjo anywhere on the returner pipe, so i guess ill have to make one myself.
        anyone know how the «block CAP» on the engine block is fasten? Do i just pull it out?
        Audi S2 Coupe
        Audi A6 C7
        VW T5
          • Dec 2017
          • 5992
          I think I saw the water pipe on Audi Tradition.
          The plug should just tap out. Careful not to score the mating surface on the block.
          • Lopez90
            • Oct 2019
            • 119
            • Country: Norway
            #50
            Got a few tips on the s2forum Facebook page how to remove the cap.
            Removed some dead weight while i was under
            Removed oil filter housing, oil cooler pipes, turbo oil return line
            Gotta admit i was afraid i couldnt do it with the engine in the car, but got tons of space after removing everything.
            Drilled a hole, in with a big screw and a crowbar
            Placing a order from 034 tonight for a new cap so i can get out some water
            Strange to actully block it this way, and not block the orginal hose
            Audi S2 Coupe
            Audi A6 C7
            VW T5
            • Lopez90
              • Oct 2019
              • 119
              • Country: Norway
              #51
              Had my first 7 meters with the car today. Out and in of the garage
              My stick is VERY loose. i have no problem getting the car in gear, but the stick is loose. Searched how the stick looks on other s2', and it looks like im missing some black plastic around? Could that be the reason?
              Audi S2 Coupe
              Audi A6 C7
              VW T5
              • Lopez90
                • Oct 2019
                • 119
                • Country: Norway
                #52
                Some time has gone since last update. Have driven the car 50 meters. Bought fox motorsport stainless exhaust. Very satisfied with the sound! But now something odd has happend. The car runs suddenly rough on idle and alot of smoke comes out of the exhaust. This happened ofc right before i was to test drive the car now on saturday... any ideas what could be wrong? Havent Done anything with the car other than change coolant and powersteering fluid. Installed new Bosch spark plugs after this happened. Sounds almost like it doesnt run on all cylinders
                Audi S2 Coupe
                Audi A6 C7
                VW T5
                • larsaskogstad
                  • May 2020
                  • 674
                  • Country: Norway
                  #53
                  Si ifra om du vil bli kvitt bremsene foran, kjøper de gjerne Akkurat kjøpt meg et 91' prosjekt selv. Kjøpte du den som lå ute til 180k?
                  (sorry for Norwegian, nothing too see haha)
                  https://www.s2forum.com/forum/member...-3b-1991-coupe
                  • Lopez90
                    • Oct 2019
                    • 119
                    • Country: Norway
                    #54
                    blir vel ikke å kvitte meg med noe på den. ikke den som nettopp lå på Finn nei
                    Audi S2 Coupe
                    Audi A6 C7
                    VW T5
                    • larsaskogstad
                      • May 2020
                      • 674
                      • Country: Norway
                      #55
                      Lov å prøve hehe
                      • Lopez90
                        • Oct 2019
                        • 119
                        • Country: Norway
                        #56
                        Resurrecting the thread again.
                        I have had a slow progress really, thinking its been 4 years since i bought the car
                        It's road legal now atleast so i have had some time to enjoy the car.
                        Gonna dump a few picture of it here.
                        Audi S2 Coupe
                        Audi A6 C7
                        VW T5
                        • Lopez90
                          • Oct 2019
                          • 119
                          • Country: Norway
                          #57
                          I have had issues with the car for years causing it to only boost 0,5 bar.
                          After numerous throubleshooting thoughtout the years i never really got a answer what the issue was.
                          - New knock sensors
                          - Tried with another N75
                          - Disconnecting MFTS
                          - Tested with other ECU
                          - Tested with other turbo
                          - Checked the exhaust and cats for blockage
                          - Checked if the car got WOT
                          - Rinsed and cleaned injectors
                          - Had some minor boost leak from injectors wich is now good
                          The car had 7A cams on both intake and exhaust so i got myself 3b cams. For some reason the boost actully got better after the swap, so i'm confused what the issue was. Thinking it has to be something with the timing on the dizzy. Trust me when i say i looked over timing on the car plenty of times before the swap.
                          I now have 1 bar overboost - i feel like i still is have boost issues. The car should boost more than 0,7-0,8 with chipped ECU?
                          Read somewhere on the forums that the one-way valve on the breather line could be faulty if i get air coming out of the metal pipe when i block it from the MAF - Turbo hose? I get some air when i boost test so i have ordered a new one-way valve.
                          Audi S2 Coupe
                          Audi A6 C7
                          VW T5
                          • Lopez90
                            • Oct 2019
                            • 119
                            • Country: Norway
                            #58
                            Got 1 bar boost stable now. Sleeve on throttle wire was the issue, so i didnt get WOT.
                            Car runs abit high on idle when warm.
                            Pulled 00533 - Idle SPeed Regulation
                            10-00 - Adaption Limit Not Reached.
                            No issues with the car other than some kangaroo in 1st and 2nd gear on low rpm and speed.
                            Idle between 1100-1200 when warm, lower when cold.
                            Audi S2 Coupe
                            Audi A6 C7
                            VW T5
                              Sounds like MAF or boost leak.
                              Remove the pins from the MAF connector one at a time and clean between the contact faces (or replace them completely).
                              Do a proper boost leak test. Replace any original vac lines with new. Check particularly the vac/pressure line to the ECU via the moisture trap and the lines to the fuel pressure regulator and branches from there.
                              Check the diaphragm of the DV is not split, the actuator line should hold vacuum.
                              HTH
                              John
                              • Lopez90
                                • Oct 2019
                                • 119
                                • Country: Norway
                                #60
                                Did a boost leak test a few days ago, so i'm gonna look into MAF wiring. It has a cable joint near the MAF so it could be bad connection.
                                Installed Blaupunkt SQR46 headunit. Replaced the Nokia speakers in the rear panels with Focal PC130. Perfect fit, only used self tapping screws on the orginal metal plate. Had a old 12" sub and a older rockford fosgate amplifier laying in the attic for years that i thew in the car. Luckly the trunk cover hides everything
                                Audi S2 Coupe
                                Audi A6 C7
                                VW T5
