Audi Coupe Quattro 2.3 20V - Czech Republic
Thanks for the advice Steve, I decided to disassemble the ABS units I had and make one (maybe two) functional. I cleaned the threads, as well as the valves. The motor was slightly stuck on the shaft, so it's running now. I'll put it in the car soon, bleed the air and hopefully the ABS will be fine. -
Well, another setback, i changed abs unit and make a new brake lines and try if the abs motor works with bridging pins 30and87 on the big relay and no sounds. The old abs unit with bad thread works but this isnt. Honestly i dont have any more power to work on this car.
Bought different brake lines and now the work is much better. Hopefully the brake lines will be done at thursday, after i could bleed the brakes and start preparing the bumper for paintLeave a comment:
ABS brake lines torture continues...I decided to split the long brake lines to have a shorter one part because of easier to remove/change in the future, however as there is a Phaeton brake booster that is much thicker its much closer to ABS and next to ABS and master cylinder i have a adjustable rear brake bias unit, so its completely brake line mess there and I am not able to bend/shape the brake lines to fit nicely without any drag
I have already started thinking of removing the ABS unit to have a space there for the lines, but I kinda want to have ABS there for safety reasons
Also, maybe i will relocate that adjustable rear brake bias valve somewhere far away from ABS and master cylinder to have more room there.
Any ideas/thoughts?Leave a comment:
Yesterday, I fitted a bumper over 100mm thick IC, and you can see what I had to cut, but it's there
. Now I have to make some mounts and also design some brake ducts into the bumper. Overall, I am happy with how the bumper looks. Hopefully, it will last long. I am thinking of making some reinforcements inside the bumper to keep it more rigid.
I removed the ABS unit and seems that 3 threads are hit, so either have to change to another unit or re threaded it with M12. Not decided yet. Also I tried to fit the bumper and there are a few collisions, so have two options, change IC to thinner one, but also have to re make the IC piping and stuff around or cut out the bumper, in few spots. What do you think folks?Attached Files- 8f85f9cb-de92-49cc-89ca-92c90e6f5855.jfif (66.6 KB, 186 views)
Yeah, could make another thread for Porsche.
Well, finally, I got an RS2 plastic copy front bumper, and on first sight, it looks very promising. Now have to make some brackets. Hopefully, the IC will fit there
.otherwise i have to buy a thinner one and made a modify the IC piping again
No engine. There was an engine, 2.5, but I want it without an engine as I want to swap it with a 1.8t AEB. Thanks Dave
Always had a soft spot for the 944. Passed up on a late S2 with a 968 engine
. Regret that. It was only £3k. What engine has she got? Looks nice
To make things even better, I bought a smaller dream. It will be a long-term project and the car will be mainly for racing/fun. I'm considering either a 1.8t or a 5cyl engine, which are already extremely expensive
But back to Audi... today should arrive a new front bumper. Hopefully wont be any damage, also have to removed the ABS unit this week to look how the threads looks, thinking of making a m12 inside threads if necessary.Leave a comment:
Thanks, it was challenge to make that pipe but ends really well.
I hope that abs threads are fine, just some vibrations loose the fittings.
Car is streetcar,
will see how long I will like that scream
but this could be redone if needed
Quite a bit of work on the intake pipe. Assuming this is 1/4 mile or track toy with that screamer pipe?
Also sounds like you may need a new ABS unit if the threads are shot.Leave a comment:
Custom aluminium turbo intake pipe is done, it was a challenge to fit under the fender, but its done. Now have to wait for front bumper . Bad thing is a ABS unit is leaking on two spots, have to check if its because of the brake lines fittings got lose or the threads inside that abs unit isnt in the best shape. It happened after a 20km of driving. Could be ABS unit threads somehow sealed? Permatex 54540 for example?Leave a comment:
Rik tip with a80 b4 washer tank was perfect and yesterday i installed one, perfect combo, also could you that second pump for IC spray if needed.
Now have to focus on making a cut out in the engine bay to make a turbo air filter piping, which will be routed through fender and inside the bumper.
No other option than making it this way, otherwise i would remake the whole turbo manifold/downpipe,etc...Leave a comment:
