Audi Coupe Quattro 2.3 20V - Czech Republic
  • Tom_
    replied
    Rewired the ECU and ignition straight from battery trough fuse/relays and now its around 14.22V, so much better now.
  • Tom_
    replied
    The MaxxEcu is wired as the stock ECU and because of this the ecu sees 12.8V-13,22V on idle. I made lot of measurments yesterday and the problem (voltage drop) is mostly in the old fuse box. So now I want to directly wire the ECU from battery to have at least 14V voltage.
    Does anyone with aftermarket ecu have the same problem/experience?
  • Tom_
    replied
    Thank You JW....Now i have to focus on minor things...
  • struikie
    replied
    Well deserved to be able to drive it now !
    JW
  • Tom_
    replied
    Thanks guys, I really appreciate it. Too bad a lot of the older photos don't work here anymore, but at least some of the newer ones are here.
    Anyway, this isn't the end, as they say, a proper project is never finished
  • rxl
    replied
    congratulations
  • Solfella
    replied
    Just read through your entire thread. Inspirational to say the least. Congratulations.
  • Nuvo
    replied
    Congratulations Tom!
    I hope you get many years of trouble-free motoring, you certainly deserve it given the amount of blood, sweat and tears you put into your project.
  • Tom_
    replied
    After 3,5 years of work, lot of work, lot up and downs..... I have an MOT again for another 2 years
    Some details, geometry, still need to be fine-tuned, but otherwise the car is ready for some km.
  • Tom_
    replied
    9.6 I am going to MOT after 3,5 years of building, so fingers crossed
    To make matters worse, I discovered an electrical problem, the interior lights are on even when the key is in the ON position, the lights are still on and the relay was very hot. It looks like the blue relay probably has a cold connection and it also looks like a problem with the door switches or light switches.
  • K Simmonds
    replied
    I'm pretty sure I used generic grain of rice bulbs inside my old 3B switch as I purchased 100 of them which will probably last me for life.
  • Tom_
    replied
    No problem, i already bought another PCB, and it seems OK, however there is one dead bulb, any idea what bulb it is? Thanks
  • K Simmonds
    replied
    Originally posted by Tom_
    K Simmonds There were two types of diff switches. The early one (longer push button) and late one (smaller button). I have early one, so if you have the early one laying somewhere around, please take some detailed pics of that PCB and routes. It will help me a lot to replicate a new PCB or at least know how it was back then. Many thanks
    Hey Tom, my apologies for not digging a switch out and taking some pic's, I've hardly been down the workshop for the past week or so due to family commitments as well as having a stinking cold and I completely forgot about this.
    I'm sure I've got at least one early type switch from my 1990 S2 that I can take some decent photo's of inside.
    I'll be down there on and off this week sorting out the huge amount of B5 spares that came with my recently acquired TDI Sport as they're getting in my way and annoying me. Once I've cleaned up my benches from prepping and paint a load of parts I'll happily take time to take the switch apart, at the moment it's chaos and I can't work like it.
  • PeterS
    replied
    Thank you,
    Yes, you are right, i have to make something similar like your nephews car. It looks nice.. What material is that? Its secured via screws? Some flanges on the radiator? welded or glued? Thanks
    https://www.michaels.com/product/pla...ology-10567988 - corrugated plastic project board (probably ABS) from a craft store
  • Tom_
    replied
