Folks, what is the cheapest/best front bumper that has the most depth for the IC? I Have to buy one, but don't want to spend a ton of money if there will be a lot of cutting necessary...
Audi Coupe Quattro 2.3 20V - Czech Republic
The holder for the screamer pipe is done (simple flat bar bent), then I removed the second spring from the wastegate, so now it's only a single 11psi spring for the beginning (just to be safe). The hot charge pipe is also ready, the cold pipe needs to be welded. Bov will be fitted on the IC outlet.
The engine bay is filling pretty much , so not sure where I am going to fit some swirl pot
Attached Files- Snímek obrazovky 2025-02-21 094900.jpg (99.6 KB, 229 views)
- 480839822_595678753305215_3623083461669235103_n.jpg (143.7 KB, 205 views)
Audi Coupe Quattro 2.3 20VComment
Ic piping and Ic itself are fully welded and pressure tested. The IC cross-member with oil cooler mounting points is also done. The custom snub mount bracket is finished. Finally, I could assembly the Ic piping. Next week I will start to bleed the brakes and ABS as well, after this, hopefully I will be able to ran car at least a few km around.Audi Coupe Quattro 2.3 20VComment
I had to switch from euro CQ bumper to the euro V6/S2 style bumper in order to fit my S2 intercooler. The official names of those bumpers may not be totally accurate. I can provide pics if you need them.2001 A4 Avant QMS - FXK04'd
1991 Audi CQ - Project
1996 A4 12v Quattro Manual - SOLD
I suspect the cheapest option with the most space would be a fiberglass copy of the RS2 front bumper, and apparently these can now be sourced in GRP.
Figerglass and very expensive shipping!
https://www.ebay.co.uk/itm/262236602...2BtISGZHQODMeE
ABS Plastic with much cheaper shipping... This would be my choice.
https://www.ebay.co.uk/itm/256707780...Bk9SR57XnaK5ZQ
Or a genuine Audi V6, now very expensive!
https://www.ebay.co.uk/itm/196870660...Bk9SR9Sb1KK5ZQ
1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.Comment
It actually says it is GRP later down the listing?I suspect the cheapest option with the most space would be a fiberglass copy of the RS2 front bumper, and apparently these can now be sourced in GRP.
What does GRP mean? I will order that plastic copy of rs2 bumper. I think it would be the best option to have as much space as possible. There will be some tweaking with that bumper, but hopefully I can handle this on my own.
Currently I am in the middle of bleeding the brakes and finding a spot for mounting the ProVent 200, looks like there is a spot near the downpipe. Maybe with some heat wrap it could handle the heat there.
Glass reinforced plasticNothelle S2 Avant
Urs6 plus project goneComment
Yesterday was a big milestone. The first few meters I drove the car. Well, it's more likea race car than a street car
And to be honest I was pretty nervous about first ran. I have a small fuel leak around DP so I decided not to drive it much and rather bring it back to garage to solve these issues and also the cam cover is little bit leaking, so I will buy a new camcover gasket or use it together with some RTV?
But the clutch acting weird , as the clutch is grabbing almost at the "rest" position.
The clutch is completely new, just everything.
New Clutch master cylinder
New Slave cylinder
New clutch throw bearing
707 clutch plate
7A flywheel refurbed
6 puck KEP disc from KL racing
I thought the new clutch should grab at the lowest point or at least somewhere down.Audi Coupe Quattro 2.3 20VComment
Well done. Did my first proper drive yesterday as well. Always things to fix after this!
No expert on your clutch set up but could it be the that the slave rod is now a little too long?Nothelle S2 Avant
Well done to you as well
Could be, but I set the height difference between brake pedal and clutch pedal (+10mm higher) accordingly to bentley manual. Not sure If its good as there arent plenty stock parts left
but I did it, so brake pedal is approx 10mm lower than clutch pedal.
Maybe pull the slave cylinder and take a measurement to see if the rod is too long. You should have quite a lot of pedal movement before the clutch releases.Comment
