My 1996 Silver ABY Coupe
That would be cracking mate, and I'll make it worth your while
Let's hope they haven't binned them.1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.Comment
Am working on mine to lots of money being spent but the end result will be worth it full restoration as you know it's in good condition but am a perfectionist lol!! Keep the photos coming
I know what you mean Anthony, real money pit but it's worth it when the car is in a good condition and in the end you can finally enjoy all the hard work, time and money spent
1996 S2 ABY SilverComment
Bit of an update, got the RS2 wheels on finally! Started her up and she idled beautifully today, can't really see what the problem is but I know there's a lot waiting for me once I get the inlet off..leaking injectors and I fear of what is under there but I'm prepared
DPP_2439 by ryanaqui, on Flickr
DPP_2440 by ryanaqui, on Flickr
DPP_2441 by ryanaqui, on Flickr
Will get some uploaded when I'm home. I've got the car in the garage and the work has started, the intake will come off and have the new one installed along with all the other maintenance items on my list with a set of Roose ancillary hoses & water hoses. Just to make a list of the things that will be replaced and I will also list part numbers for anyone who needs them
Lambda Sensor PN 0258003957 - Bosch
N75 Valve - ABY Specific - OE 034906283K
MFTS and Thermoswitch
Knock Sensor - Short on back of block (Blue) - 0261231036 - Bosch
Knock Sensor - Long on front of block (Green) - 0261231038 - Bosch
Mahle Thermostat - 70807794 - TX2587D
Engine speed + Ignition Timing Sensors (Meyle 1008990100)
3.5 Metre Vacuum Hose
New coolant tank
Injector Seats 034133555
Throttle Body to Intake sealing Gasket 034133073H
Inlet manifold gasket
Sealing washers N0138115
Oil Switch
Valve housing: 034103247G - OE
Valve: 035103245A - OE
T-Piece Hose - 034133367E - OE
Intake temp sensor: 034905379B - OE
Injector Oil Seals: 06A906145 - OE
2.0TFSI Coils - 0341072000 x 5 - OE
5x NGK BKR7EIX-11 gapped to .06mm
Oil Pressure Sender: 035919561 - OE
Might have missed something, will update with pics later today when I'm back home, hoping nothing goes wrong
Cheers Gav, got some nice pics here and got a pic of what you need but I need to upload it from my mobile
. Manifold is on, now just a few more bits & bobs, change the downpipe, MK3 seat rails have been cut and re-welded + sprayed. Tomorrow the seats should be going in and they are looking sweet
With the RS2 cups on
DPP_2443 by ryanaqui, on Flickr
Parts for the car
DPP_2446 by ryanaqui, on Flickr
Roose ancillary & coolant hoses
DPP_2449 by ryanaqui, on Flickr
Work in progress..
DPP_2451 by ryanaqui, on Flickr
DPP_2452 by ryanaqui, on Flickr
DPP_2453 by ryanaqui, on Flickr
DPP_2454 by ryanaqui, on Flickr
And her resting place for tonight
DPP_2460 by ryanaqui, on Flickr
More to come soon!
