When arrived I'll have a wheel show'n'tell
Resurrection of my CQ20V
Yes it is filthy, but will stick it through a car wash this eveningAttached Files
So... new wheels, rubber and and a fresh MOT no advisories, and now the clutch pedal has dropped to half height!
Doubt very much it is the actual clutch, as a) I am running stock 170BHP and b) it was replaced around 50K ago, with a genuine item.
So guess it is hydraulics, or the plastic 'bud' on the end of the slave, will check it once light tomorrow, and see what's needed, apparently the slave is a right piggy to get to....
Seal turned maybe........wonder if changing the fluid would help? A bit of air in there might cause the same thing?
I've changed my brake fluid a couple of times since getting my coupe, but........I'm guilty regards bleeding the clutch.....never done it
I'm more guilty then... brake fluid never changed, oops
Sounds like a contender, going to pull the panel under steering column to look for fluid there, otherwise I guess it will be slave out, a flatbed doesn't sound very inviting to me.
Oh, and a couple of litres of fluid, to change it all out(!)
Originally posted by Vorsprung durch Technik View PostI'll wait for a clean picture then! Can't really see the car Oh pictures of the radiator shrouds with the aux rad brackets are needed.
Will get some snaps in a bit, but you realise they are all hidden by the top bit
Originally posted by Bowie69 View PostOi I live out in the country, it would get that dirty in a week out here. Was going to stick it through the car wash last night, but getting home was a priority over having a clean car
Will get some snaps in a bit, but you realise they are all hidden by the top bit96 URS6 plus speck saloon
