Resurrection of my CQ20V
  • Bowie69
    • Nov 2013
    • 2675
    Now, the other side.....
    Drop in what ever this is called....
    And then the difflock lever:
    And then the locking collar, this is what moves to lock the first bit you fit, with the inner part of the drive flange, at this point, screw in the two locating bolts for this arrangement, one of which you can see the pin of at the bottom of this picture:
    On the outside of the case, two of them go here, and one more the other side, I have since cleaned up the bolt heads!
    Put this little plunger in here, followed up by the mangey difflock indicator switch:
    Not forgetting to de-mangey the switch:
    Next, the mahoosive seal for the other side:
    No seal drive I had was big enough, so went old school:
    I think I need to tap this one in a little more, it is just rubbing on the back of the drive flange once fully assembly thankfully, the outer edge of the seal is not hidden, so will be able to tap it in easily enough.
    The drop in the other flange, and shove the unobtainium bolt in the middle and it is done....
    • Bowie69
      • Nov 2013
      • 2675
      Now, the input, ready, for a seal:
      Sealed, with a 52mm socket, and a smudge of grease:
      Nut installed, torqued to just past where it was before, with home made flange restrainer:
      Nut was re-staked.
      And then you end up with a hole in the bottom needing filling. I found something to do the trick:
      As above, from a classic beetle, mit magnet, from JustKampers.
      A nice hole stopper, sitting flush:
      Then you end up with something looking like:
      Couple of other things to note, I have a hose clamp on the difflock lever, I will likely change it out for a stainless fuel pipe clamp style one, which was what was on there before, well, that was what the remnants of it showed me it was.
      Couple of marks to the paint, will touch up before installation.
      Now I need to find somewhere to store it while I get the rest ready!
      • Bowie69
        • Nov 2013
        • 2675
        Another small, on-vehicle job I tackled, was a £184 experiment:
        People tell me the Whiteline BAR14Z is designed only for the S2, including people on here. After much poring over OEMPC, I couldn't find a justifiable reason for this for a 1990-on coupe. The earlier vehicles, such as Alex's, has a different arrangement, attaching to the lower wishbone, but not so on mine, and from what I can see, not so for any post 1990 coupes.
        First hurdle was just a heavy dose of scepticism :
        Grease free, silent, friction free, maintenance free, all the things that sound like snake oil.
        The lubrication is apparently PTFE based and sits in here on the fluffy innards:IMG_20200927_172409.jpg
        Apologies for the quality, very tricky taking that!
        No matter, after some deliberation, I slapped them on the bar, and fitted it up:
        It werks!
        One issue I had was the factory bolts weren't really quite long enough, plus they were a bit past it, so I found what I had in the garage to make it work:
        These will be replaced with something with a larger head, quite soon.
        You will notice, that the brackets are shoved as far back as possible, this can best be explained by the following photo:
        Initially, the bar was really quite close to the wishbone, now, it should have been OK, as everything moves with each other, and should really only get shorter, I wanted to be sure.
        It is possible that the cast wishbones on the S2 (they did have them on the rear as well, right?) are a little narrower at this point, and would give better clearance, and no necessitate the shoving of the bracket. That said, the brackets are slotted, and they must be for a reason. Unless it is to standardise them between kits?
        Be interesting if anyone has a photo of their whiteline setup on their S2 to compare?
        Just to confirm to people, it looks an identical path to the old one:
        SO......... is it any different.......? Oh yes, none of that initial lean in you get with these cars on stock suspension, just sharp turn in, and when you hoof it in second, the back definitely wants to come round more, while the front just sticks and carries on turning in.
        I find myself not having to turn the wheel as much as I used to, which I wasn't expecting...
        All that within just a 3 mile test drive
        • Bowie69
          • Nov 2013
          • 2675
          The eagle-eyed amongst you may have spotted one or two misty areas under the car....
          Seeing this yesterday made me realise I did absolutely the right thing getting a replacement rear diff:
          I'm seeing:
          • Left output flange seal
          • Right output flange seal
          • Left Inner CV leaking
          • Right inner CV leaking
          Oh dear
          • SteveH
            • 4460
            Nice write up and pics
            91 Modded 3B
            14 A6 Avant Black Edition
            • Lago Blue
              • Jul 2009
              • 843
              Thanks Bowie for taking the time to add those diff damper photos sir, quite illuminating. I had no idea that it might one day come apart like that (one more thing to go wrong!), good to know!
              Cheers.
                • Dec 2017
                • 5991
                Very nice clear pics. Makes me want to pull mine apart just for the sake of it.
                Re those unobtainable bolts. If they are the same as the Ur Diff, they are still available from TPS. I bought a few earlier this year.
                • simons2
                  • Mar 2010
                  • 344
                  I replaced my arb with the same whiteline one today on my 3b , it fits exactly like yours but is slightly closer to the wishbones ( pressed on the s2 ) , I had to use larger washers on the brackets and hence reduced adjustment, imo the slots are too wide , as you allude to , the handling is so much sharper with better turn in and a more tail happy balance, however I have also replaced the inserts with Koni adjustables plus top mounts , bump stops and gaters so I’d expect an improvement , lol
                  • Bowie69
                    • Nov 2013
                    • 2675
                    Yeah, there are a couple of lengths, these are 94mm and the less common version, when I could find then, it was ~£15 a bolt, plus carriage from Europe, was beginning to get silly!
                    So not unobtainable, but certainly made of unobtanium.
                    • Bowie69
                      • Nov 2013
                      • 2675
                      That's really helpful, thanks, so in other words, identical fitment to the S2!
                      I wonder why they don't market them for the CQ, could sell a few more.
                      I drove it again tonight, about 20mins, the car feels so much lighter, but it was wet, and I didn't want to slide into a kerbstone and ruin a wheel, so I was a good boy
                      • steve briance
                        • Aug 2014
                        • 1455
                        Excellent reporting!
                        I've subscribed this post to come to in the future at some point.
                        I've also been contemplating the whiteline ARB. you experience the same positive results everyone else does - there must be something in it! Which of the 3 holes did you bolt the drop link to for your first drive?
                        • Bowie69
                          • Nov 2013
                          • 2675
                          Thank you
                          Stuck it in the centre hole for the moment, and left it there, will adjust in the future for sure, but it feels good for the mo.
                          • Bowie69
                            • Nov 2013
                            • 2675
                            Oh, and I went direct, arrived quickly, Demon Tweaks wanted 3-4 weeks before dispatch for some reason:
                            Boost grip with performance car suspension parts from Whiteline. Rule every street & track with the best sway bars, coil springs and polyurethane bushes.
                            • simons2
                              • Mar 2010
                              • 344
                              Center hole for me too , I went to Balance Motorsport , it arrived the next day
                              • John.
                                • 2615
                                Nice write-up Mr Bowie, doing similar to my CQ.....just taking a lot longer to do it, too much other stuff needing done!
