Mrc600
This is a sticky topic.
  • Doug_RS2
    • 3847
    #46
    turbo, manifold and WG
    • 1975DCS
      • Sep 2006
      • 258
      Originally posted by 4WheelDrifter
      The short block is what you see in Doug's picture here.
      It's like the long block, but without the cylinder head.
      Uhm ok... I have seen the pic but don't know what it means... Is it a shorter stroke engine?
        "Short block" just means "engine without cylinder head" (and no gearbox or ancilliaries)
        • K7ERG
          • 1711
          Looks good doug! been a while since i last spoke to you on here....
          Craig
          Audi A6 AEL 5cyl Quattro breaking.
          Audi A5 3.0tdi Quattro Stage 2
          07947385043
          • A1QSHIP
            • Aug 2004
            • 975
            Front crank pulley
            Where did you get the front crank pulley assembly? How much lighter than stock is it? Is the main cap support plate available commercially?
            Just what I need to see... more bits and pieces to wonder about.
            "Nulla tenaci invia est via"
            • WabTheKing
              • May 2004
              • 2567
              • prosty
                • Jun 2005
                • 1114
                Nice project. I'm using a gtech pro SS for my 0-62 times, but if I go by 60 feet and time on the dragstrip, I'm pretty sure my car does it under 4 seconds (full weight avant) , the gtech was 0.1 secs off (slower) than the NHRA approved timing equipment used, when I set my 12.48 ET.
                Looking for middle / low 11's , so 3.5 seconds 0-62 should be the goal there.
                Good luck with your project! Really clean and nice!
                2004 9-5 aero
                2009 Subaru Legacy Diesel
                1994 Toyota Supra Eurospec 6-spd LHD
                3-4 Audis in parts
                  Originally posted by WabTheKing
                  Another MRC! This could get slightly confusing!
                  • Doug_RS2
                    • 3847
                    #54
                    Slow progress but machining work has been done on the manifolds and turbo.
                    • Doug_RS2
                      • 3847
                      #55
                      manifold machined so water manifold fits and isv pipe welded in
                      • Doug_RS2
                        • 3847
                        #56
                        nipples, nipples and nipples
                        • Doug_RS2
                          • 3847
                          #57
                          nipples
                            How much would that work cost on the manifold cost normally Doug?
                            • Doug_RS2
                              • 3847
                              #59
                              i'll get a price if you want it. I got the ISV pipe done, the machining to fit the water manifold, the fuel rails holes drilled and tapped, the pulley hole drilled and tapped, and all the nipples on the manifold. I also got the turbo WGFV nipple welded on and silicon hose strap bosses.
                              • Chris M
                                • Sep 2003
                                • 1030
                                How come you've gone with a different IM Doug? Your old one not upto the job??
                                Cheers,
                                Cheers,
                                Chris
                                Silver S2 Avant : Sold
