Originally posted by quattrito
View Post
My Ocianic Blue Ur restoration
Originally posted by joss01 View PostHi Dave if you have access to your clutch slave cylinder change it even if it works I have a new unit if your interestedNothelle S2 Avant
Easy car to work on and you get it right they look great and Simon from Classic Quattros is a good help careful Quattro corner is a bit pricey for partsAttached Files
- 2 likes
Good plan. How easy is it to get the heater matrix out? Looks completely different to my S2
Joss, your old Ur looks great there.
I have made some small progress over the last few days. It's slow as most of the bolts and screws are seized or rusted up
This gallery has 1 photos.Nothelle S2 Avant
Originally posted by joss01 View PostI did my heater matrix I don't think i removed the dash but it requires major surgery as for the slave cylinder if your car is a left hand drive I think exchanging the slave cylinder is easier as the pedal box is not in the wayNothelle S2 Avant
Sorry Dave i thought comedy else was asking about the location of the slave cylinder. Access to the slave cylinder when the engine is out will make life easier but you may still have to remove the pedal box the bulkhead has a double skin making repairs to the matrix a slave a pig of a job.
Slowly getting there. Rear is now nearly stripped.
The front drivers A pillar is the worst I have found so far.
The front wing bottoms came away in my hands 80% filler, 19% rust, 1% paint!
I'm on the lookout for repair panels if anyone has any knocking about
Originally posted by joss01 View PostI suppose you can say you dont have your hands full. It looks scary but doable check your passenger door I have a good spare.Nothelle S2 Avant
I had a full day in the garage today and made good progress.Exhaust offProp shaft offAll wishbones off (they are past it)All abs sensors removed in one pieceRear brake pipes calipers and carriers offRear tie rods off (one is dead)Rear off side drive shaft offNearside driveshaft won't budge on the inner cv join. All the bolts removed, is it just bonded on with corrosion or is the diff lock holding it?Subframe bolts at the rear cleaned and soaked in oil ready for a go at them tomorrow.I still have lots to do. Every single bolt is fighting back and its all taking ages.Nothelle S2 Avant
