jbrentd's 2nd Chance CQ
  • jbrentd
    • Dec 2009
    • 247
    Originally posted by LSG
    I think Arron was the fella your referring to. who did the carbon sill trims, Although i have not seen him post for a long time.
    Yes, I guess I should have pulled the trigger way back when.
    2001 A4 Avant QMS - FXK04'd
    1991 Audi CQ - Project
    1996 A4 12v Quattro Manual - SOLD
    • jbrentd
      • Dec 2009
      • 247
      It's nice to be putting parts back on the car for a change. I bench bled and installed the new master cylinder, connected the hardlines, ABS pump, booster, rack, stabilizer, and tie rods. Also spent way too long fumbling with the battery cable grommet.
      Since I am switching to an evap canister that goes in the fender, I’m trying to figure out where to cut the fuel tank vent line that goes to the evap canister. I think I might just cut it right above the firewall bracket that used to sit below the battery tray (like was suggested on another forum) and run a rubber fuel hose to the evap.
      • porci82
        • Jul 2012
        • 58
        • Country: Switzerland
        #78
        What a great rescue, awesome job!
        Keep on going!
        • jbrentd
          • Dec 2009
          • 247
          Keep on going!
          Thanks!
          More stuff making its way back on. 3B wiring harness and what’s left of the 7A wiring harness, coil, bomb, washer tank, hydraulic fluid reservoir, new hood release cable.
          Made a bracket for and mounted my fan resistor pack. Also got most of the fan wiring done.
          I also attempted to make a set of rubber flaps that go in the fender well around the tie rods. I think they turned out okay.
          • Bowie69
            • Nov 2013
            • 2675
            Those flaps look great, what material did you use?
            One of mine is very torn.....
            • jbrentd
              • Dec 2009
              • 247
              Thanks. I used this stuff, along with hole punches, rivets, and some plastic retainers.
                • Dec 2017
                • 5992
                Tractor tyre inner tube also works well
                • jbrentd
                  • Dec 2009
                  • 247
                  With a screen name like your, I suppose you might have a few of those laying around.
                    • Dec 2017
                    • 5992
                    One or two
                    • jbrentd
                      • Dec 2009
                      • 247
                      I think all I have left on the power/ground front is to make a new ground wire for the bell housing and to change the positive terminal on the 4 awg wire to the starter.
                      • jbrentd
                        • Dec 2009
                        • 247
                        Progress has been SLOOOWW!! Pretty typical for me in the Summer, with the heat and lots to do around the house. I’ve also started the process of building a dedicated detached garage/shop. I hope to break ground later this month. But here are a few updates…
                        Although I was able to get the auxiliary relay panel mounted up, I don’t think I’ll be able to get the knee bolster on with all the guts hanging out below. :-). Not sure if I can poke them in or will have to unplug everything and go about it a different way.
                        I couldn’t pass up some local OZ Ultraleggeras.
                        Got the transmission, front subframe, and front suspension back.
                        Built a new ground wire for the transmission. I may have to bend the lug on the transmission in order to get the bell housing bolts on.
                        I was surprised to find the 3B’s firewall bracket fit right in behind the coil. The holes lined up perfect. This is where I’ll put the timing, rpm, knock, and O2 sensor connectors.
                        Got the carbon canister relocated to the fender and hoses routed.
                        • steve briance
                          • Aug 2014
                          • 1455
                          Super clean and tidy job. personally i like the details of whats underneath more than a perfect paint job on top, i dont know why as nobody ever sees it but, i just like knowing its good underneath.
                          • Bowie69
                            • Nov 2013
                            • 2675
                            It's OK, the MOT man see it, his remark at my recent one was 'Quite clean underneath isn't it?'
                            • jbrentd
                              • Dec 2009
                              • 247
                              Thanks! I would kick myself for years if I did not take the time to clean things up while in this process.
                              I guess no one will see it then...no MOT/inspections here in Oklahoma.
                              • jbrentd
                                • Dec 2009
                                • 247
                                I have very little to update on the coupe, but I hope to re-gain some momentum soon. Back in November, we started construction on a detached shop and it has taken up most of my free time. I'm still working on moving stuff over from the old garage, most notably, the coupe. After finishing up the front suspension, it's back on its feet again for the first time in almost 2 years. And my son and I were able to get it pushed over to the new space...much to my wife's approval.
                                I was also able to re-cover the front door cards with some new foam underneath the original leathers.
