Started work on the car again. First up the squealing Brembo brake pads.
Went with a set of TRW pads as I found someone selling off some old stock TRW pads, they had a couple of sets left so got both of them. I don't think many people rate the standard S2 brakes so don't think there will be many cars running around with the twin pot Girling setup, so I'm guessing the supply of them will go EOL at some point.
After taking the wheel off on the passenger side, I was met with some what of a oily mess. It appears that one of the clips holding the power steering pipe to the reservoir was just not the correct diameter and even fully clamped it was still allowing fluid to drip through and cover the running gear with fluid including the brakes. When I removed the pipe I noticed a good 1mm in thickness between the crimped section and the uncrimped. So I'm guessing the ear clip I put on was just a little to big.
Drained and removed the pass bottle then washed all the paintwork around the area and refitted using slightly smaller ear clips.
once the leak was stopped the wheel arch and running gear was cleaned off and the brakes were then fully cleaned with brake cleaner and the new pads fitted.
These were the old Brembo pads from the car, with the contaminated set on the right. Ignore the circle marks on one of the pads I used it to push the pistons back into the calliper.
Now I've not been driving the car much over the last few months but it never felt like it was pulling to the right under breaking, but I'm glad I found the issue and it all been sorted.
It's also difficult to monitor the level of PASS fluid in the reservoir on the car, as over time when the engine is switched off the fluid level rises over the maximum and then returns to the correct level when the engine is running. The question is where is all that fluid coming from the BOM? Also is it normal?
