Looking very smart. I might have some of those pins. How many do you need?
My S2 coupe bit of a rebuild and repair thread.
Next up on the rebuild list is the drive shaft covers. They are looking a bit worse for wear to my astonishment no longer available from Audi.
After an removing underseal, carefully cutting the foam away then degreasing and finally a bit of sanding & scraping your left with these slightly less scabby bits of plastic
Found some neoprene foam 10mm foam from the arch & 5mm foam for the sides. Now I'm not sure how well the neoprene will hold up over time but like the old stuff it can be cut back and replaced.
To stick the foam back to the plastic I used this stuff. Zap superglue. It was the superglue of choice to glue the tyres onto the rim for 1/5 large scale petrol r/c cars. The tyres used to get a lot of abuse from performing burnouts to get heat into the tyres and they would last a 30minute of racing without any problems. I performed a quick patch test and the foam had to be cut and sanded back for it to be removed.
So gluing the foam and fingers to the plastic (will buy the thicker Zap next time) they were finished.
I know the cut outs look a bit rough and I would have preferred cutting them with hot wire rather than scissors, but I think they will do the job and will be better than the foam that was stuck to them. Also made it difficult get a template out of them.
Did these last last night so still waiting to see if they fit on the car.
Was also hoping to get a lot further with the front-end build but my daughter was not felling well and I looked after her yesterday, so just managed to get these bits on early in the morning before the Mrs went to work
For the bottom ball joint, I managed to find some of these plates (old stock febi) as the last joints were just held on with individual nut & bolts.
So today it's brakes and anti-roll bar back on the car. Also going to try and get the rotten oil cooler off the car which I wanted to do yesterday.
Nice work. On the drivers side, the driveshaft cover originally had a heat reflective cover. I used the flexible reflective fiberglass cloth you can buy from Merlin Motorsport for a reasonable price.Nothelle S2 Avant
- 2 likes
More very tidy work, I really like your attention to detail. As Dave says the drivers side would have had a heat reflective layer, fiberglass cloth is the way to go here, same on the drivers side chassis leg next to the turbo.1989 B3 2.0 3A 80 quattro... Budget 1.8T Project.
Originally posted by Tractor Dave View PostNice work. On the drivers side, the driveshaft cover originally had a heat reflective cover. I used the flexible reflective fiberglass cloth you can buy from Merlin Motorsport for a reasonable price.
So where I got to this morning. Brake lines fitted started to blead the brakes.
Does anyone know how much brake fluid is need to completely flush the entire system including what fluid is in the reservoir. Was thinking 2 litres should do the job. At the moment I'm just letting gravity do the work, I think if I applied pressure to the 26 year old reservoir it's just going to burst apart so will be replacing that soon.
Covers look OK, think the side pieces of foam are a bit thick, will look around for some 3mm stuff.
Need to find a solution to this clip that goes on this nut as the cable is rubbing against the bolt. Ones on my car were both damaged
One thing I have done is to cover all the nuts, bolts and metal brake connections in a 2k clear etch lacquer, this is the same stuff you paint diamond cut alloys with. It won't 100% stop the rust but I've found it keeps most of it away, and it far easier to cut through a thin layer of paint than thick layers of rust.
Next up is to fit the ABR parts.
- 2 likes
I think Audi still sell the bolt cap with wire clip. I got some new ones but can't remember where from. I may have one or two if you are stuck.
I spray all my bolts and lines with Bilt clear wax. Great stuff.Nothelle S2 Avant
Originally posted by Bowie69 View Post2 litres will be plenty, I use a pressure bleeder without concern on my 30yr old reservoir....Nothelle S2 Avant
Originally posted by Tractor Dave View PostI think Audi still sell the bolt cap with wire clip. I got some new ones but can't remember where from. I may have one or two if you are stuck.
They dropped them 8 years ago.
It's a pain when you hit silly problem like this due to a bit of plastic. If you have have any please let me know
The one on my 25 year old A4 was very much shot, and was at the back so you could not see it easily. It's why for the time being I'm used gravity which works fine just takes a while...
Well, had enough for the day. what a sod to remove one of the oil cooler pipes
First of all got the ARB fitted which was easy enough. Need to sort that downpipe at some point!
So next was to remove the old cooler it's been dangling down for weeks, and it needed to be removed. So as the pipes going onto the cooler were stuck solid, the only option was to remove the top pipes, and tackle the cooler off the car. First pipe was easy enough but the second was a complete and utter pig. Got creative in the end with a pair of adjustables, that just fitted inside the engine bay.
With the cooler now free from the car the pipes going into the cooler were removed using the following tools mapp gas torch, Self-locking pliers, adjustable spanner and a length of scaffolding pole. Oil cooler is totalled...
However the pipes are saved, one less thing I need to buy!
Tomorrow something nice and easy paint the wing.
