My S2 coupe bit of a rebuild and repair thread.
  • B5NUT
    • Sep 2021
    • 1071
    Originally posted by Mikes2
    When I removed Koni shocks from one of my cars and that plastic sleeve had been fitted on top.
    This is where a found the instruction on the plastic sleeve and it show around the base of the shock. but as the instructions are useless I could be wrong
    This is why I hate aftermarket parts, they can be a complete pain in the backside to fit.
    • Mikes2
      • 1704
      Sorry - should have been more clear. On top of the shock housing - just like that. The anti-freeze is to prevent overheating of the shock and is important.
      Mike
      http://www.s2-audi.co.uk
      • K Simmonds
        • Dec 2007
        • 7627
        The idea of the anti freeze in the strut tube is (I think) to stop the shock body seizing in place and being a pig to remove, I've never bother with doing that on any of the the car's I've worked on, instead I give the outside of the shock body a coat of WD40 and squirt a bit into the shock housing. That's always worked fine for me, and to be honest I've also put them together totally dry as well when working in a hurry.
        The plastic ring is (again I think) to act as a dirt scrapper to protect the seal in the top of the shock, never bothered with those when I fitted my Koni's as they didn't look like they'd help at all, in fact I thought they'd simply act to trap crap underneath them.
        The Koni's I fitted to my old S2 were the previous top adjustable type (make's much more sense) and I got them second hand so no instructions to confuses me even further, they didn't come with that sleeve, though they did come with the (IMO) pointless plastic disc's.
        I fitted mine with a washer on top (the same one I removed from the old shocks) and as I say no sleeve. My car was a 3B as opposed to ABY, though why that should make a difference as to whether there should be a washer in that location or not truly baffles me.
        My RS2 had washers in that location when I rebuilt it's front suspension, so go figure!!!
        I've got to pack up some eBay stuff now and head out to the post office, so will be busy for a bit but I'll be back online this afternoon, you seem to be pretty competent mechanically so I'd go with whatever feels right to you if you want to fire everything back together now. Yes, aftermarket parts/instructions can be a PITA!!!
        1990 B3 2.0 80 quattro.
        1992 C4 2.8 Avant quattro
        1994 MTM RS2.
        1998 B5 TDI quattro Sport.
        2000 B5 TQS.
        • Bowie69
          • Nov 2013
          • 2675
          Replacing all four of mine recently, I was surprised to find that the two front shocks had no washer, and the two rear did -I had checked the EPC and saw the listed washer, but eventually came to the same conclusion -not used on 7A or S2.
          • B5NUT
            • Sep 2021
            • 1071
            I'm never going to track the car so I don't see why they would over heat, and on the Bilstein threads they talk about drilling holes in the bottom of the strut to allow any trapped water out, so it all somewhat confusing, why would the Koni overheat and the Bilstein not unless it's down to when you set the stiffness of the shock absorber.
            When I dismantled the shock, I don't remember seeing any washers and I don't have any spare ones around. So I'm 90% sure the ABY models don't have one! I think.
            Well If I have to remove them and add a washer at some point it would be easy enough now that all the bolts are not rusted solid. What I don't want to do is rush the job & make and **** of it, as it just ends up costing me time & money.
            I've got the high build primer to rub down this morning so I have plenty time to think things over.
            • K Simmonds
              • Dec 2007
              • 7627
              That's interesting, good to know the actual thinking behind reason for it.
              1994 MTM RS2.
              2000 B5 TQS.
              • Rikki Kitto
                • Feb 2010
                • 6276
                You should look up lago blues top Mount kit before you put it back together bud
                • Mikes2
                  • 1704
                  It's not just Koni. OEM were the same - factory manual advises a small addition of antifreeze. Bilsteins are a different design internally so need the hole drilled. Regarding the washers. ABY S2s didn't get them
                  Mike
                  • steve briance
                    • Aug 2014
                    • 1455
                    The anti freeze in shock tube trick was around in the days of ford dealer team escort mk2 rally cars. I guess thats extreme service but the theory is the same - aid cooling by improving heat transfer from shock to body to atmosphere.
                    The holes in strut tube for bilstein cars is to let water out. The internal bump stop design of the bilstein shocks means that, if enough water gets in and stays in; the area of shock body which has the bump stop in it becomes hydraulically locked and solid. Your piston and bump stop no longer move and your ride becomes a bit rough at that point!
                    • K Simmonds
                      • Dec 2007
                      • 7627
                      Now I've thought about it the physics behind antifreeze in the shock housing does make complete sense, as there's no air surrounding the insert the transfer of any heat to the housing will be more efficient. Though any fluid should do the same job, I guess they recommend AF as it's non flammable, won't freeze and isn't corrosive. I've encountered gear oil being used for this purpose a couple of times and as I've said used WD40 myself, though now I've thought about it not sure that's such a good idea, it gets very flammable when hot...
                      Sent from my SM-A115F using Tapatalk
                      1994 MTM RS2.
                      2000 B5 TQS.
                      • steve briance
                        • Aug 2014
                        • 1455
                        Flaming suspension struts batman!
                        • K Simmonds
                          • Dec 2007
                          • 7627
                          Indeed, I'm going to use antifreeze from now on as directed, you learn something everyday. Though I'm not going to loose any sleep over using WD40 in the past, it's pretty well sealed in once the cap is torqued up and non of my or any of the cars I've used it on have ever caught fire or exploded, though I guess it's theoretically possible. Having had to use massive home made slide hammers (combined with swearing a lot) a couple of times to get seized in place inserts out I just (wrongly) assumed it was prevent that happening.
                          1994 MTM RS2.
                          2000 B5 TQS.
                            Totally agree the method of damping adjustment is absolutely poo!
                            However .. a few of us ended up here
                            Originally posted by newsh
                            Koni settings
                            Assuming they’re the ones you have to set before you put them on the car, and you adjust by pushing the rod all the way downwind turning it.. ( very annoying, it used to be possible to buy “top adjustable“ versions)
                            On the S2 this works quite well.
                            Front - 1 turn clockwise from full soft
                            Rear - half a turn clockwise from full soft
                            • B5NUT
                              • Sep 2021
                              • 1071
                              So after many many weeks I finally have some shocks on the car.
                              Also fitted the first of the 2 flexi pipes.
                              I'm also having trouble getting hold of these plastic clips anyone got any? They hold the rubber steering arm covers in place
                              • B5NUT
                                • Sep 2021
                                • 1071
                                Was also working on the wing after applying a guide coat
                                blocked back the initial coat of primer and found what remained of the dent.
                                So a bit of this stopper was applied. Excellent stuff if you have very minor imperfections to fix.
                                Apply like normal filler and leave to go hard, then sand back with your required grit
                                So final primer has been applied. That will be smoothed back tomorrow before before the base & clear coats are applied.
